Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Info on Tenor TE7022?
Old 27th July 2012, 11:53 PM   #11
kevinkr's Avatar
TE7022L is adaptive, not asynchronous.. (Think jitter) Getting drivers for class 2 USB is going to be a problem. I would look at an xmos solution - they have dev boards, software and can provide a proper USB asynchronous driver for it.
Galaxy Far East Corp is not particularly diy friendly, nor frankly are their ASIO drivers particularly good in my opinion. (I have a dac that uses this device in addition to Stello U3 xmos based asychronous USB to spdif driving my good dac.)
There are threads here based on the xmos chipset.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th July 2012, 11:06 AM   #12
Stanga is offline Stanga  United Kingdom
You mean the TE8802L. There are a couple of issues with the operation of that chip on some operating systems and micro processors.
Old 29th July 2012, 04:40 AM   #13
kevinkr's Avatar
Actually I don't.. The dac I am talking about has a TE7022L in it plain as day, and it has the issues I mentioned in my post both in Win7 and XP OS. I've had it apart repeatedly for unrelated mods and have a close friend who has one as well with exactly the same chip & problems.
Old 29th July 2012, 09:01 AM   #14
A bit of cross talk here. I was replying to post #10.
But as to your own comments about jitter: in USB it is only an issue if you are going from the USB into the DAC chip via I2S. If you are going into a receiver chip like say the WM8804 or CS8416 the data is reclocked and jitter correction implemented. Async is fully dependent on an I2S connection before it can surpass adaptive USB. When a receiver IC is used however between the USB input and the DAC chip, both USB methods produce the same end result. USB to SPDIF adapters that use async are therefore of questionable improvement.
Old 29th July 2012, 03:31 PM   #15
kevinkr's Avatar
Probably good to quote a small part of the post you are responding to so it's clear..
Good point if you go through a good spdif receiver like the Wolfson or BB, but even so I found the xmos set up to sound (totally subjective I know) significantly better than my various other interfaces which are either m-audio soundcard or adaptive usb, all into a WM8804 spdif receiver.. Not really entirely sure why that would be and I don't have the test equipment to do a deep dive on this question - so it's anecdotal based on observation, and given what mu Stello U3 cost I would have to admit there might possibly be an unconscious (not deliberate) expectation bias at play as well.
Old 8th September 2012, 08:23 PM   #16
Does anyone know what the Master/Slave select function is for on the TE7022? I have seen it on the datasheet but it is a complete mystery to me what it is for, and when it should be used.
Old 16th October 2012, 07:30 AM   #17
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
If not mistaken,it's related to the on-chip HID function...
Old 29th October 2012, 05:29 PM   #18
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
This is surely the easiest way to implement this device into a project:
24/96 TE7022L USB CARD for DAC5
Since the difficult soldering has been done and presumably the software is loaded. It's designed for a particular system (DAC5) as a daughter-board, but I assume it has pins on that header for USB in and S/PDIF outs?
Old 19th December 2012, 04:00 PM   #19
quantran is offline quantran  Viet Nam
Send a message via AIM to quantran Send a message via MSN to quantran Send a message via Yahoo to quantran
The product information sheet states that the core runs on 1.8v power. If i want to inject the clock signal from an osc, should it be 1.8v clock or 3.3v?
Quan Tran
Old 20th December 2012, 12:31 AM   #20
Leolabs's Avatar
3.3V
Info on Tenor TE7022?Hide this!Advertise here!
Gran Tenor juliovideo Tubes / Valves 14 16th July 2009 09:19 PM
Need info on my Onkyo, can't find any info anywhere. gixxierific Digital Source 0 19th April 2009 03:49 PM
How to get cathode bias info from grid bias info? leadbelly Tubes / Valves 8 14th August 2008 04:40 PM
Got info?! looking 4 info on the BG Neo 10 gp4Jesus Planars & Exotics 1 18th November 2006 03:14 AM
Best Coltrane Albums - Great Tenor Sax Recordings Gabrielshorn Music 16 2nd October 2002 07:01 PM
