| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
They both uses Philips SAA7350, can someone tell me whether the I2S inside is oversampled (2Fs or 4Fs) or non-oversampled (Fs)?
#2 | |
Abracadabra I have the schematic but don't know where to look to tell you if it's 2Fs or 4Fs or NON-oversampled. If you can tell me where to look, I'll help you. Audiofanatic
Be nice to animals. |
#3 |
What is the SAA7350 connected to? What dacs do the 2 players use?
ray. |
#4 | |
Hi DIY'ers, The CD-72SE uses no other DAC than the SAA7350 thats the only one uses in this CD-Player. The CD-72 MKII uses the SAA7350 conected to a TDA 1547 (DAC7). Thats the only thing I can tell! Regards, Audiofanatic ![]() P.S. te Analogue output of the SAA7350 is 34-35-36-37-38. for right & 19-20-21-22-23. for left. IOW BAL. output. I wish I had a scanner
#5 |
The SAA7350 is a dac itself but is often used in conjunction with the TDA1547 where it functions as a bitstream converter. It can also be used with an external digital filter. To find raw I2S data you may have to look further back. The table below shows the different input formats the SAA7350 will accept. The IDF pins determine the format and they are
IDF3 pin3, IDF2 pin4 & IDF1 pin5 |
#6 |
Hi Audiofanatic,
Just before the 7350, what laser decoder does it use? 7210 or 7310? Thx
#7 | |
The CD72SE uses a PCF3523 DIGITAL Output a SM5840FP DIGITAL FILTER and before the two a SAA7310/HS DECODER. I hope it's enough information for you, if not, let me know! Regards, Audiofanatic
#8 |
Thanks a lot, Audiofanatic,
Any chance of emailing me a copy of the schematic? Getting a scanner soon? |
| Marantz CD52 (again!) tray disassembly help | Nijinsky | Digital Source | 10 | 21st December 2010 10:09 AM |
| Marantz CD72 Tray issues | Duncan | Digital Source | 5 | 11th December 2004 12:48 PM |
| Need help with Marantz CD72 service manual | patwen | Digital Source | 5 | 25th July 2003 08:35 PM |
| marantz cd72 mod help | piewie | Digital Source | 2 | 10th February 2003 08:25 AM |
| Page generated in 0.08180 seconds (85.09% PHP - 14.91% MySQL) with 11 queries |
