diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Source (http://www.diyaudio.com/forums/digital-source/)
-   -   DENO DCD-620 : Is it possible to have à S/PDIF output (http://www.diyaudio.com/forums/digital-source/175538-deno-dcd-620-possible-have-s-pdif-output.html)
29manu29 17th October 2010 04:45 PM
3 Attachment(s)
I have a DENON DCD-620, it don't have a S/PIF output and i would like to add one (i have a Sencer DAC PCM 1564A). This cd player have a CXD-1125Q chip. I've jointed the schematic. I've found the DCD-1560 schematic, this CD player use a cxd-1125Q and have a coaxial and an optical output, the numerical signal is take on #27 pin (DOTX). On DCD-620 this pin is GTOP, i hope the fonctionnality of this pin is function the states of #55(MD1), #56(MD2), #57(MD3), on DCD-620 the states are :
MD1 = "High"
MD2 = "Low"
MD3 = "High"
and on the DCD-1560 the states are :
MD1 = "Low"
MD2 = "Low"
MD3 = "High"
If i change the state of MD1 is it possible to made a S/PDIF output on my DCD-620 ? If yes does it need resistor and capacitor
stephensank 17th October 2010 08:48 PM
You are correct. Once you alter those MD connections, all you need, minimally, is a 75ohm series resistor between the DOTX pin and the output jack. Cap and/or transformer optional, but not desirable, IMO, unless you have ground loop issues.
JesseG 17th October 2010 09:33 PM
29manu29
As stephensank says, this is an easy fix. I have done the same with several Yamaha CDPs that were not equipped with Coax digital out. get some very fine 0.5mm wire and solder carefully to the pad of pin 27. Then find a ground on the same chip and solder another wire there. Twist the two wires carefully together and solder to ground and 75 ohm r soldered close to the center of a good quality RCA (or better, a BNC) that is ISOLATED from the chassis.
Happy listening
29manu29 18th October 2010 07:18 PM
Thank you a lot for your replies. I'll try it soon (i'll post a new message)
Manuel
29manu29 28th October 2010 10:01 AM
2 Attachment(s)
I've tried to tweak my CD player. First when i've opendes my CD player, my MD1 = "Low", MD2 = "Low", and MD3 = "High", for me no modifications were necessaries. I've soldered an little coaxial wire on pin #27 (look at picture) and i've soldered a 75R between the center of the RCA and the end of wire (look at picture). When i connect my dac without CD in the CD player, my DCA detects a signal, two leds, "48KHz" and "Lock" are lights on my DAC. When i put a CD the motor doesn't run on my CD player. I've tried to connect my DAC when a CD is readen, the CD player motor stops also. Somebody have an idea ?
Manuel
poynton 28th October 2010 01:32 PM
2 thoughts:
Ground loop causing problems - move your grond to a star near the PSU.
Loading of the chip is wrong - insert resistor or buffer with a gate chip?
Andy
29manu29 28th October 2010 05:22 PM
I've resolved my problem i've soldered a serial 220R with the wire and the center of the RCA and i've soldered a 75R between ground and center of the RCA. It's perfect.
Manuel
pistone 15th February 2011 05:07 PM
how?
Manuel
Hi Manuel, can you explain better? Even with a photo? Thank you!
Lautar 17th February 2011 08:50 AM
1 Attachment(s)
its 100% tested and worked shem
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
