Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Marantz CD-5003 Mod
Marantz CD-5003 Mod
Old 9th April 2013, 09:45 AM   #21
michelino is offline michelino  Italy
Don't worry .... have you already tested some mods?
Old 9th April 2013, 10:43 AM   #22
Roushon is offline Roushon  India
Not yet. At the moment accumulating informations and
taking a closure look at the circuit before attempting any changes. I usually take a little time to start...need to grasp many things...
Roushon.
S. Roushon
Old 20th December 2013, 04:49 AM   #23
Default Finally!
Finally, I have began the modification in my Marantz
CD5003. Kindly tell me if I can replace the ICs NJM2068
by AD8620 or LM4562. They are pin equivalent.
At the same time upgrading another player where the IC
is NJM4580. Can this be also replaced by one of the
above ICS.
Thanks in advance.
Roushon.
S. Roushon
Old 22nd December 2013, 03:28 PM   #24
adhiyasa38 is offline adhiyasa38  Indonesia
from datasheet, NJM 2068 input bipolar, AD8620 jfet.
people in diyaudio, say that LM4562 is good op amp, but bad performance if using as unity gain.
This op amp for filtering high frequency, safe and cheap choice using NJM2114 ( as marantz cd17 or cd6000).
Old 24th December 2013, 02:57 PM   #25
Originally Posted by Roushon View Post
How does one do this shielding for some particular IC? It will be very good to see some picture.
Thanks and regards
Roushon
you can use, materials are easily around us :
1. cut new pcb, same as ic outline.
2. using alumunium for sealed powder milk cans.
3. alumuniuium from building store.
using silicon seal or double tape for fixing shielding.
Old 24th December 2013, 03:29 PM   #26
Thanks Adhiyasa for pointing out the differences between the ICS. I am getting
OPA 1612 which is input bipolar to make the replacement. Hope it is OK.
Roushon.
S. Roushon
Old 24th December 2013, 03:31 PM   #27
I really liked the idea of using copper clad board. Will use a double sided (both sides shorted) one.
Thanks and regards
Roushon.
S. Roushon
Old 10th November 2014, 11:32 PM   #28
Andersonix is online now Andersonix  Sweden
Andersonix's Avatar
Marantz CD-5003 Mod
I am getting
OPA1612 is a fine choice.
Looking forward to more updates!
Old 11th November 2014, 03:28 AM   #29
Oops! It is such a long time since I logged into the forum.
All the parts are ready to make the update, but finding no time to dive into the project.
Thanks for your reply.
Roushon.
S. Roushon
Marantz CD-5003 ModHide this!Advertise here!
What Transport in Marantz CD-5003 *** New Launch *** arupg Digital Source 1 30th September 2008 07:05 PM
Marantz CD75mkII to mod or not to mod that is the question. El_Hefty Digital Source 6 31st August 2006 01:29 PM
Marantz CD-7 audio output mod. D.A.R.R.Y.L. Digital Source 23 5th June 2006 08:23 AM
Marantz Cd-4000 / Philips Cd-723 (tda1545) maartentje Digital Line Level 1 10th June 2002 05:28 PM
