Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd January 2013, 12:54 PM   #11
Oh, I've forgotten my last post!
The kwak clock is now correctly installed in my marantz cd5003! The clicks were due to a bad connector to the ground.
Roushon, I'm very busy in these days because I'm working to my thesis for the bachelor degree at the university but for sure as soon as I've time, I'll let you know
Old 4th January 2013, 09:44 AM   #12
Roushon is offline Roushon  India
Thanks for your response. I will look forward to your posting. In the mean time best wishes to your thesis...I wrote my thesis long back and know how involving it is.
Roushon.
S. Roushon
Old 21st February 2013, 10:50 PM   #13
Lightbulb CD 5003 Upgrade
Hi everybody!
As promised, I've ended and exposed my thesis and so we can now talk about our marantz cd5003. Here are my mods. For shure there will be other improvement to do but these make the marantz way way better than the stock one .
Enjoy
MARANTZ CD 5003 MODs
AUDIO PWB:
C612, C712 -> 20uF + 20uF MKP
C602, C702 -> 3300pF XICON 23PS (styrene)
C604, C704 -> 330pF XICON 23PS (styrene)
C605, C705 -> 1000pF XICON 23PS (styrene)
C607, C707 -> 1500pF XICON 23PS (styrene)
C615, C715 -> 1000pF XICON 23PS (styrene)
C608, C708 -> 100pF 1000V WIMA FKP2
C616, C716 -> 100pF 1000V WIMA FKP2
C609, C709 -> 330uF 25V PANASONIC FM
C610, C710 -> 330uF 25V PANASONIC FM
C761 -> 470uF 25V PANASONIC FM
C753, C754,C758 -> 220uF 10V NICHICON FP-CAP
IC61, IC71 -> OPA1612
IC77 -> MINIVREG +5V
Put 0,1uF 50V X7R between the pins + and - of: C609, C610, C709, C710.
Put 0,1uF 50V X7R between ground and the pins VL, VA of DAC CS4392. Keep attention during the soldering of these two caps to avoid short circuit.
Bypass HDAM and muting circuit: remove R623, R723 and connect the node R627/C616 and R727/C716 (HDAM input) to the respective RCA output plug with 40uF (or 20uF + 20uF) MKP capacitor. This mod is a MUST. If during ON/OFF the cd player generates some “bump” sound, you can use two reed relays with 5V coil to put the output to GND and remove these bumps. The relays should be controlled from the input of Q603 and Q703 (to be tested but should work). The diodes D605, D606, D705, D706 provides about 4.5V on the cathode when the audio should be muted. If you do this mod, the swapping "C612, C712 -> 20uF + 20uF MKP" can be omitted because this mod bypasses C612/C712.
For minivreg, schematics are available on the web. Soon I’ll update my PCB design.
HEADPHONE PWB
C801, C802 -> 330uF 25V Panasonic FM
C803, C804, C807, C808 -> 47uF 50V Nichicon Muse KZ
IC81 -> OPA1642/OPA1612
MAIN PWB
C216, C218, C221, C223, C462, C466, C467 -> 330uF 25V Panasonic FM
C326, C327, C341, C401, C405 -> 330uF 25V Panasonic FM
C325, C362 -> 470uF 25V Panasonic FM
C251, C253, C313, C346, C349, C360, C364 -> 220uF 10V Nichicon FP
Clock Mod: remove C260, C261, X251 and connect an external clock on PIN1. Note that the output voltage of the clock must be of 3.3V MAX. 5V clock may damage the clock synthesizer CDCE913. Soon I’ll upload my design of kwak clock modified to obtain 3.3V clock output.
POWER SUPPLY PWB
C913, C917, C919 -> 3900uF 25V Nichicon HE/Panasonic FM
C911, C912, C916, C918, C920 -> 2200uF 16V Panasonic FM
C915 -> 330uF 25V Panasonic FM
I've even swapped the diodes on the power supply pwb with ultra fast UF4003 diodes. I can't remember if there were sound improvement.
Let me know.
Michele
Old 22nd February 2013, 09:41 AM   #14
Congratulation on finishing your thesis! Thanks so much for painstakingly typing the detailed mod. I am taking print of this list and one of these days will open the player. First, I have to source the parts.
I did not understand the clock mod part. How does it help? Also are the schematics of the player available on the net?
Thanks again!
Roushon.
S. Roushon
Old 26th February 2013, 04:26 AM   #15
I just downloaded the service manual of the cd player.
Thanks!
Roushon.
S. Roushon
Old 27th February 2013, 05:28 AM   #16
Just looking at the schematics and surprised to see the use
of parts like 1N4003 and 78XX series regulators etc. I thought before I have a high-end cd player, now see that even in my LM3886 based amplifier I used better quality parts. Just dying to mod this player.
S. Roushon
Old 27th February 2013, 05:57 AM   #17
Originally Posted by adhiyasa38 View Post
cover digital chips with rfi shield.
How does one do this shielding for some particular IC? It will be very good to see some picture.
Thanks and regards
Roushon
S. Roushon
Old 28th March 2013, 02:49 PM   #18
Default CD5003 CLOCK and REG
clock and regulator schematics attacched. Enjoy!
Old 28th March 2013, 03:31 PM   #19
Default Photos
As requested, here are some photos of my modded marantz.
Marantz CD5003
http://s11.postimg.org/vte62m3oj/IMG_0040.jpg
Clock detail
http://s11.postimg.org/teqvvxctf/IMG_0042.jpg
DAC PCB
http://s11.postimg.org/64hbdzpr7/IMG_0045.jpg
Supply PCB
http://s11.postimg.org/fu4pajmeb/IMG_0050.jpg
Headphone PCB
http://s11.postimg.org/y5zy5fkf7/IMG_0051.jpg
Shielding of IC detail (cut a piece of copper and connect it simply to the closest GND point)
http://s11.postimg.org/uswawgg83/IMG_0052.jpg
Digital PCB
http://s11.postimg.org/cz5usa3hf/IMG_0053.jpg
About the clock mod, the purpose it to have an external circuit to feed all the audio digital IC like the DAC and reduce jitter fluctuations. On this forum or on the web you can find tons of info about such kind of mod.
Hope the pics are useful. Bye!
michele
Old 9th April 2013, 04:25 AM   #20
Impressive indeed and many many thanks for taking the trouble to post the details and pictures...
Roushon.
S. Roushon
What Transport in Marantz CD-5003 *** New Launch *** arupg Digital Source 1 30th September 2008 07:05 PM
Marantz CD75mkII to mod or not to mod that is the question. El_Hefty Digital Source 6 31st August 2006 01:29 PM
Marantz CD-7 audio output mod. D.A.R.R.Y.L. Digital Source 23 5th June 2006 08:23 AM
Marantz Cd-4000 / Philips Cd-723 (tda1545) maartentje Digital Line Level 1 10th June 2002 05:28 PM
Copyright ©1999-2013 diyAudio
