Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
New DAC born
New DAC born
Old 8th July 2003, 10:16 PM   #1
mdlover is offline mdlover
Default New DAC born
Hi all,
Just complete my first NON-OS TDA1543 DAC.
The 1543 is operated at 8V, Riv is 1k5 and Rref is 1k.
Well, the sound is refreshing and musical. When comparing to my previous PCM63 DAC, this little converter sounds more natural.
But the story never ends..........
Old 8th July 2003, 10:27 PM   #2
Default its little brother.....
after some listening, I decided to try something other than passive I/V.
First thing drawing my attentiion was Rudolf's simple I/V for the 1543.
The new DAC using this active I/V was built and the sound is even better, more dynamics, more details and the background is more quiet than the original passive version.
Next I will try to improve the supply section, new BJTs, new output Caps ............
BTW, I would like to thank Rodolf for sharing his I/V design.
Cheers.
Old 8th July 2003, 11:15 PM   #3
fedde is offline fedde  Netherlands
Nice work!
Good luck in your adventures...
Fedde
ps. And try a passive version with 2.4k and 3.8 Vdc level!
http://www.fedde.nu, gainclone, non-oversampling DAC and open baffle audio projects...
Old 9th July 2003, 09:02 AM   #4
rbroer is offline rbroer  Netherlands
rbroer's Avatar
MDlover,
Looks really nice
Since my pcb's are really tight, it's hard to try some other things.
With the active I/V there are some things you could try:
Try different supply voltages for the TDA1543,
like 5V, 6V, 7V, 8V to hear if there are any differences (my guess is it will be subtle compared to passive IV)
Try different voltages on the base of the common base transistor
(try varying the 4.7k resistor setting the current through the two leds)
Increase the positive rail; this enables you increase the Vce of the common base transistor which is a good thing.
Increase the current sink, this lowers the impedance of the common base transistor
Use better transisors like 2SA970BL and 2SC2240BL
One thing I did this week was replacing the 2W (magnetic) carbon resistors is was using for Riv with some DALE RN60C's
I never bothered about resistors but this spot seems quite critical
A certain edge has gone and upper bass, lower mids improved a lot. Sounds much warmer without loosing detail.
If you're willing to do some tweaking, I would love to hear some feedback.
Could you let me know some of the voltages, currents and parts you are using, have set-up ?
After my vacations I'll implement the "not so very simple active I/V" which is DC coupled , uses better parts, has a lower impedance that the DAC will see, etc.
Will let y'all know the results of course
Rudolf Broertjes
Old 9th July 2003, 10:22 AM   #5
Hi Rudolf,
Thanks for your advice.
I use 6V for the TDA1543 currently. And the I/V stage supply is around 14.2V (7808+6.2V zener), the base voltage of Q3 is around 3.3V (I use 3k3+1k5 for R7).
Will tweak this circuit and will let you all know the results.
Cheers
Old 9th July 2003, 11:07 AM   #6
miguel2 is offline miguel2  Portugal
Is Rudolf's schematic available?
Miguel
Old 9th July 2003, 02:43 PM   #7
takashi is offline takashi
yours seem better than mine..
Old 9th July 2003, 08:43 PM   #8
Miguel
http://www.diyaudio.com/forums/showt...threadid=17226
Cheers
Old 10th July 2003, 10:20 AM   #9
New DAC bornHide this!Advertise here!
Another GC is born! mantisory Chip Amps 10 6th July 2006 04:35 PM
One more DIY TT is born livemusic Analogue Source 18 20th December 2005 10:44 AM
New Aleph30 born mpopovics Pass Labs 4 15th July 2005 07:47 AM
new gain is born sith Chip Amps 9 4th October 2004 07:27 AM
A new Aleph3 is born... Smithers Pass Labs 9 10th January 2003 02:41 PM
