Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 30th September 2010, 10:44 PM   #1
cuibono is offline cuibono  United States
cuibono's Avatar
Default Transformers on the Output of a Soundcard
Hi All.
I currently use my computer for various DSP functions - EQ, XO, phase correction, volume control. The problem, although my soundcard measures amazingly (Asus Xonar D2), it has ground loop problems - in particular, I can't get it to shut up! I've tried a number of different things, and I've decided to try using transformers on the output.
I've already got six Edcor wsm 10k/10k line matching transformers. I'm currently working up an opamp output stage for each transformer, because I assume I can't just leave the secondaries of the transformers flapping in the breeze. Correct? I don't really want to, but I think I have to.
The schematic is mostly done, I'm doing the layout now. I'll post them when I can. A lot of trouble for a little ground hum...
Any feedback would be appreciated!
Old 30th September 2010, 10:54 PM   #2
Did it Himself
richie00boy's Avatar
What's wrong with just connecting the secondary to your amp input?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 30th September 2010, 11:36 PM   #3
cuibono's Avatar
That would be easy wouldn't it. The thing is I won't be using the computer with only one amp. But perhaps I should commit to using just one amp with the computer...
Old 30th September 2010, 11:46 PM   #4
cuibono's Avatar
here is the schematic for 4 of the 6 channels of the soundcard isolator.
the transformers go between the pads on the left.
There is a rotary switch (4p3t) in the middle of the circuit, which allows 0, 10 and 20 dB of attenuation before the opamp. This is to allow the soundcard to be operating with less digital attenuation. The switch is in the middle/top of the schematic, but all the connections are not drawn.
The schematic is still a work in progress.
Old 1st October 2010, 11:46 AM   #5
Did it Himself
Doesn't really matter if the amps are different as long as their input impedances are similar.
Old 5th October 2010, 02:49 AM   #6
cuibono's Avatar
Well, I ditched the opamps.
I now know why people don't use input transformers more - I can't get them to be quiet!! $#%$%$#$
I've been working on it for two days. I don't know what the issue is. The input transformer is more than two feet from the power transformer, I've tried all sorts of shielding and orientation, and it is as noisy as the computer that was the first problem.
If I place the transformer and shield in a very exact location (which I can't keep them at), the noise is 'only' -80dB - but in pretty much every other place, it is at best -60 to -70dB down. So frustrating!! The power amp itself has a noise floor of about -110dB, so I'm not very excited about the transformers right now...
Old 5th October 2010, 11:46 AM   #7
RIP
Bifilar wound output trafos fed directly from the card outputs would be best, if the output impedance of the card is low enough (150 ohms or so).
Trafos built expressly for output duty CAN be left flapping in the breeze, input trafos cannot. They can be a PITA to get set up right. Also, output trafos are much less susceptible to interference, and some are available in mumetal cans for zero interference.
Old 5th October 2010, 06:39 PM   #8
Did it Himself
Looks like you need a balanced output adding to your soundcard and a balanced input adding to your amp, or at least wiring the unbalanced input a special way
Old 7th October 2010, 01:25 AM   #9
cuibono's Avatar
After more looking, I came across this helpful thread. A lot of people have similar problems - ground loops and other noises from their PC's...
Anyway, in this thread, poobah posted this schematic:
I threw one together on a bread board, and it seems to work, so my thinking is to modify the input of my power amp (which also has a differential input, but I'm not using it that way).
My power amp is a 6-channel beast I've been unofficially calling "Quasimodo", just because it has become so ugly. But it works. Its based on the LME49830 opamp, and the power transformer is a 1300W monster I got for free from 'papa'.
Here is the input stage, as it is now:
I think all I need to do is unground the bottom the Ci1, but keep it attached to the shield of the RCA connector J4 (which will also be ungrounded). Then it should be operating in differential mode, no?
I'd like to lower the total gain of the amp, so I'm going to change Ri from 249ohms to somewhere around 850ohms. I suppose I also have to change Rin from 249 to 850ohms, to keep things balanced?
I'll post back when I get to it...
Old 7th October 2010, 03:59 AM   #10
Originally Posted by cuibono View Post
Hi All.
Did you try using balanced input amplifiers? Yes I know your PC is unbalanced. Tie the '-' inputs to the sleeve of the 3.5 mm connector. The '+' inputs go to the tip and sleeve. Do NOT connect the 'grounds' together directly. You can try a 100 ohm resistor just to keep the grounds loosely coupled. Do this for each of the 3.5 mm connectors on the outputs. The 'signal' lines have signal plus ground noise while ground has just noise. The differential amps will subtract the noise from 'signal plus noise' and leave you with signal. I've done this many times and it also works with analog video hum. Remember that the accuracy of the noise cancellation depends heavily on the match of the resistors but you can buy chips like this with precision trimmed resistors in the package.
http://www.analog.com/static/importe...ts/SSM2141.pdf
TI / Burr Brown has these also.
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
conecting 1 sub and 2 speakers to 1 soundcard output Jimmy154 Multi-Way 7 16th March 2006 02:30 AM
output level of soundcard? demons_wing Chip Amps 2 31st July 2004 11:01 PM
multiple output from single soundcard twill Digital Source 0 4th February 2004 06:06 AM
Multiple output soundcard as crossover? cdwitmer Digital Source 7 12th June 2003 05:02 AM
Page generated in 0.12627 seconds (81.02% PHP - 18.98% MySQL) with 11 queries
