| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hi
I have the player Philips CD610 and want to replace OPAMPS and put in common GND with the output of the transformer, but I know little about DAC. I wonder what the function of trasistors the output of opamp? Attached scheme: |
#2 |
mute function
GuidoB |
#3 |
Don't understand the "transformer gnd" bit. What do you mean.
As Guido says, four transistors at the right are muting. Middle two are deemphasis switching. Swapping the opamps would be worthwhile... and being very boring I'll still suggest OPA2604 although you may want to try the LM4562.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 | |||||
The 22k resistor (3675,3676) before the two transistors mute funcion, I seem to make a voltage divider, more leaves to very high output impedance. Quote:
#5 |
The 22k resistors reference the output electroylitic and mute transistors to ground. Common practice to do that. The resistor is high enough to have no effect on the output at all as it's fed from the opamp output.
The mute transistors, two are used per channel to get a "deep" enough level of muting in conjunction with the 470 ohm resistors. These two 470 ohm in series define the output impedance of the player. The deemphasis transistors are the two in front of the opamp that change the hf filter characteristics. All the transistors and diodes at the top are used to provide the logic levels required to operate the mute and deemphasis circuits. The OPA2604 is just a personal favourite I find works well
| How to specify a transformer for dac output? | sharpi31 | Digital Line Level | 12 | 3rd March 2010 09:15 PM |
| dac - passive output ? | 2cc | Digital Source | 1 | 18th October 2008 04:43 AM |
| Converting Dac-in-the-box's DAC chip to I/V output | Aleksunder | Digital Source | 0 | 22nd January 2007 12:44 PM |
| Class A output DAC | PTSOUNDLAB | Digital Source | 2 | 30th April 2003 06:34 AM |
| Page generated in 0.08182 seconds (74.00% PHP - 26.00% MySQL) with 11 queries |
