Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Revox B126 CD Player Malfunction- Help Needed (TDA1541A-CDM4/27)
Old 10th October 2010, 04:11 AM   #11
amc184 is offline amc184  New Zealand
amc184's Avatar
Looking at the symptoms you describe, I think the problem is still likely to be the servo. Within those first couple of minutes, can the player skip to the last tracks of a CD?
Based on the timing of the fault, it certainly does sound like a heat related problem. Do you have any freezer spray? If so, you could try spraying the different ICs on the servo board. If not, you could try operating it 'till it fails, then seeing if any of the ICs seem unusually hot.
Failing that, try replacing both the TDA5708 and 5709.
You have been recalibrating the Laser Power and Focus Offset adjustments after making each major change, right?
Old 15th October 2010, 04:47 PM   #12
dtm1962 is offline dtm1962  Canada
Default Update: Continued problems with Revox Player
Here are the sysmptoms:
It will play perfectly for 1 minute to 10 minutes depending on the temperature of the unit (Ambient). It will begin to mistracked and music becomes garbled and eventually it will stop spinning the disc. Turn it off for a couple minutes and it will start-up and play for 1 minute since it is warmed up at this point.
For example it was sitting in my unheated work shed overnight and it got down to say 4 Celcius (40 F) and I turned it on and it worked for 10 minutes perfectly.
If its a 10-15 C mid-day and I will turn it on and it will work for 2 minutes or so.
If its 20 C or 68 F, the unit will play for only 1 minute.
So I believe it is temperature related.
I have replaced the following with no change:
I changed the following on the Servo board:
All transistors, TDA5708/5709 Decoder chips, 4560 & TCA372 Opamps; the 4.7K & 22K pots; the 2 7.5V Zeners and all electro. caps have been changed and all resistors have been checked.
On the Main Board (I had some spares):
The SAA7010/SAA7020 & Memory chip associated with the SAA7010, the 11.28XX Mhz crystal, all transistors associated with the PS and IC chips.
Next up is the CD turntable Drive output transistors & the laser assembly.
Any ideas would be helpful?
Let me know.
Thanks in advance.
Dan
Old 15th October 2010, 09:22 PM   #13
Default Success!
The laser assembly seemed to do the trick......
Only thing is that it plays all commercial CD's and plays some CD-R's.
It seems to play the most scratched CD-R but will not play almost perfect condition CD-R's.
It must be the way I recorded or the brand as the scratched CD-R is different brand from the other perfect condition CD-R's that won't play.
Any idea or experience with this situation???
Dan
Old 16th October 2010, 07:40 AM   #14
poynton is online now poynton  United Kingdom
poynton's Avatar
So what exactly did you replace in the laser assembly to get the CDp going??
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 16th October 2010, 02:40 PM   #15
Andy
Hi Andy:
I replaced the laser/ribbon cable/radial motor assembly minus the CD disc Drive assembly/plastic base. So basically take a CDM4/19 and unbolt the laser assembly via 2 screws and swap out.
Dan
Revox B126 CD Player Malfunction- Help Needed (TDA1541A-CDM4/27)Hide this!Advertise here!
Revox B-201 Remote: Will it work with a B-126 Revox CD Player dtm1962 Digital Source 2 3rd August 2010 02:20 AM
Marantz CD-40 (TDA1541A & CDM4): need help! Malefoda Digital Source 1 29th December 2009 02:29 PM
Revox B126 / B226 CD Player poynton Digital Source 0 6th March 2009 06:40 AM
Revox B226 B126 spares wanted poynton Swap Meet 9 31st March 2008 12:47 PM
FS: Ariston CD1 cd player, CDM4/19 + TDA1541A(si)+OPA627BP mudihan Swap Meet 13 6th July 2006 04:24 AM
