Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 7th September 2010, 04:12 PM   #1
Default changing voltage on Philips cd930 from 240v to 120v
I have a Philips CD930 that I need to convert from 240v to 120v to use in the US. There are two jumper options, and on the PCB it shows one for 240v (which is what is connected now) and one for 220v. On the schematic it shows the 240v and then the other is shown as 220v/117v. The schematic and PCB indicate to use a 200mA fuse rather than the 100mA that's currently present. Can I just change the fuse and jumper or is there something else I'm missing? The 220 and 117 together is what's throwing me off. Thanks!
Old 7th September 2010, 05:13 PM   #2
Mooly's Avatar
I can't see a 117 option on there.
Does "reality" compare with the manual. The fuse rating is correct in being doubled for 117v.
Very crude way of measuring is to measure the primary resistance when set for 240 and see if you can get it too read half that for 117.
A simulation free zone. Design it, build it, test it.
Old 7th September 2010, 06:13 PM   #3
My guess is that you are stuck. You will need a transformer to drop the power line to 120 Volts. I don't think the change in power line frequency is a problem.
Old 7th September 2010, 07:13 PM   #4
Lautar is offline Lautar  Ukraine
Send a message via AIM to Lautar Send a message via MSN to Lautar Send a message via Yahoo to Lautar
US used 120V 60 Hz
need spatial power trans for 60 hz
Old 7th September 2010, 09:16 PM   #5
Generally a 50 Hz transformer will work okay on 60 Hz. The other way around, well not so generally.
Old 7th September 2010, 11:10 PM   #6
amc184 is offline amc184  New Zealand
amc184's Avatar
There are three versions of this player in regards to the transformer:
- A 220 and 240VAC version.
- A 117VAC version.
- A 240, 220, 127 and 110VAC version which has an externally accessible voltage selector on the back.
Since you didn't mention the obvious voltage selector on the back, you must have the first type. You can't set this player to run on 120VAC directly, best to just run it using a step up transformer.
Changing Voltage Req from 110V, 60Hz to 220-240V, 50Hz? pingpong Pass Labs 3 13th June 2010 03:09 AM
Voltage Conversion on a Bryton amp (120V->240V) usa_satriani Solid State 1 21st March 2010 11:23 AM
120v/240v amplifiers dsiroky Solid State 1 25th September 2008 11:58 AM
Spacedeck 240V to 120V lt_texan Analogue Source 3 10th December 2007 02:41 AM
Using 120V transformers with 240V supply Peter Daniel Solid State 12 21st January 2003 12:32 AM
Page generated in 0.08978 seconds (72.78% PHP - 27.22% MySQL) with 11 queries
