Simple ACTIVE I/V for TDA1543 - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 4th July 2003, 07:01 PM   #51
dddac is offline dddac  Germany
Thanks for getting me off moderation.
4 times I posted the pictures. I could see them in the off-line mode, but when my post appeared they were magically gone
Try again:
fft1
Old 4th July 2003, 07:02 PM   #52
YES IT WORKS !!!
PIC2
FFT2
Old 4th July 2003, 07:48 PM   #53
Pedja is offline Pedja  Serbia
Thanks Doede. Really instructive! To be honest, I did not believe that such figure (fft1) can be achieved with 2k or similar I/V resistors.
(I forgot to mention, in the measurement I posted Rref was 1k.)
Pedja
Old 5th July 2003, 01:51 AM   #54
fedde is offline fedde  Netherlands
Send a message via ICQ to fedde
Thanks Peter. Now I can use my crystal ball for more useful purposes!
I don't know if all TDA1543's can be used with high I/V resistors. I've heard that some will clip then...
Fedde
http://www.fedde.nu, gainclone and non-oversampling DAC audio projects and kits...
Old 5th July 2003, 09:43 AM   #55
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Sziklai input CB-CB connected (folded)
Hi Rudolf,
Here is my attempt. The setting of the pot is a bit tricky as Q5 is a current source in itself drawing also current from Q4.
I hope this works. I have not built or simulated this.
Old 5th July 2003, 12:58 PM   #56
Default I/V stage
Hallo!
The schematic below derives directly from the Passlabs D1
I build it balanced and implemented successfully into a sony CD player . In that case the Dacs were looking for a virtual ground.
Now , I'm waiting for parts (TDA 1543, receiver etc) and I have not try it or simulate it .
I wonder if it will work with TDA 1543.
Old 5th July 2003, 01:00 PM   #57
Default SCHEMATIC
Old 10th July 2003, 07:52 AM   #58
rbroer is offline rbroer  Netherlands
rbroer's Avatar
Stefanobilliani,
Sure it can work, just change the resistors so, that the gate voltage on Q1 is 2~3V higher compared to the one with virtual ground. This will lift-up the source voltage on Q1, hence the DAC output voltage.
Rudolf Broertjes
Old 10th July 2003, 12:51 PM   #59
miguel2 is offline miguel2  Portugal
Would the circuit on page 1 work well with a 4x oversampled signal? My CDM12.1 transport oversamples the signal and I dont want to mess with it.
And what are the circles with arrows inside? It is just to show the current or they are current sources?
Miguel
Old 10th July 2003, 03:04 PM   #60
Originally posted by rbroer
Stefanobilliani,
Thanks for the reply rbroer,
what about a constant current source (better PSRR), and at what current? After searchin' around in the thread and projects seems that the preferred current for the TDA1543 is around 7-8 mA for I/V ; can anyone confirm this?
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Already build 3 massive power supplies , the input receiver...
The TDA still not arrived
I take the occasion for a question that is pretty interesting for the thread:
the absolute output phase:
I noticed in different projects around the internet that just one case does an exception regarding the pins in the differential input receiver from the SPDIF. The pins are 9 and 10 of the CS8412.
Almost all projects sets the pin 10 (after the cap) at ground , and the pin 9 (after the cap) at the signal.
The TNT-audio CONVERTUS does the opposite: pin 9 at ground and pin 10 at signal.
Does this help to restore the absolute phase at the output of the DAC, since I read at the NONOZ2 DAC page that the TDA1543 inverts the phase?
Less simple I/V for TDA1543 rbroer Digital Source 42 11th April 2004 05:28 PM
Copyright 1999-2017 diyAudio
