| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Has anyone replaced the onboard oscillator of the CD-PRO2 unit with an external low jitter clock?
I have searched the forum but didn' t manage to find something about this. There was a post somewhere regarding this issue, but things were not clear. Reading the manual of the CD-PRO2 I find that there is a connector with the designation "16 MHz (optional)", but, as far as I understand this, ths is for providing the internal 16 MHz clock to an external unit. I' m interested in building a KWAK-CLOCK and feeding my unit with it. What I' m asking is where should I connect the clock (and from where should I disconnect the onboard clock). Has anybody some kind of experience with such a modification? Evangelos |
#2 | |
If you have a circuit diagram, I could be of help Most logical you feed the new clock to the input of the original crystal oscillator (after removing the crystal ofcourse) By the way, my most recent measurements on a Kwak clock showed horrible results. best regards Guido |
#3 |
Here's some info I found in CD-Pro documentation
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#4 |
Banned
Hi Evangelos,
You almost answered your own question. Just remove the original crystal and the two small caps as in the picture kindly provided by Peter. You now have to connect the output of the KWAK-CLOCK to one of the pads of the original crystal connected to CRIN. If you can not determine from the schematic wich pad is connected to CRIN just try both pads, one at a time, with a 1k resistor in series wth the clock-output. Keep the pad that works and remove the 1k resistor. I hope to visit your beautiful country soon.....
#5 |
I've made that modification. I don't remember what pin is the right one but this is critical. One of my SAA7324 died in this experiment
My Philips dealer said it cannot provide this chip even if I wanted 1000 pcs. I will look and tell you about the real clock input. |
#6 | |
diyAudio Moderator Emeritus
Hi Guido, horrible in what sense ? Jitter, waveform ? I heard/read quite some good responses on Elso's clock.
It's only audio |
#7 |
So did you complete the modification or the loss of a chip made your unit useless?
#8 |
I completed the modification on other units. Of course the one with dead SAA it's useless until the chip is replaced.
#9 |
What clock frequency did you use? From info I posted it seems like at least 3 different frequencies are possible.
#10 |
I used 8.4672 MHz external clock - ECL type with discrete buffer.
| Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. | Julien_M | Swap Meet | 5 | 25th January 2009 12:03 AM |
| One clock for CDM12 Pro2 and Nos Dac TDA1545 | gochtoni_toni | Digital Line Level | 28 | 28th November 2007 12:31 AM |
| PCM1794 DAC and CD pro2 clock | galouche | Digital Source | 0 | 9th July 2007 11:00 PM |
| 33.86 Mhz clock on CD-Pro2 | Peter Daniel | Digital Source | 3 | 25th October 2005 11:12 PM |
| Dac with external clock how and why?? | kimschips | Digital Source | 3 | 9th August 2005 11:19 AM |
| Page generated in 0.10972 seconds (89.24% PHP - 10.76% MySQL) with 11 queries |
