| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#41 |
It lives !
Added Elso's clock to the CD-Pro. Now playing music through my backup DAC - Scott Nixon 1543 DAC More info later (like how's the sound ? - can't tell at the moment). Thank you Elso. Regards, Joe Ling Malaysia |
#42 |
Hmm, can't seem to post pictures. How is it done ?
#43 | |
Banned
The problem with the pictures here is usually they are too big. If you download Irfan View from www.irfanview.com you can choose resize/resample. 800 bits is the maximum for this forum. Then just save the file as......And upload from your computer. Irfanview is free of charge! Hope this helps. Glad the clock is working. I was a bit anxious after Lcaudio's post. |
#44 |
#45 |
testing on pictures
#46 |
Let's try a bigger picture of the detail.
Note that the crystal has been destroyed while trying to pry it away from the PCB. I simpley soldered the 'clock out' from Elso's clock onto one "leg" of the crystal while the ground went to the ground of one of the capacitors on the PCB. |
#47 |
Here's a general view of the whole setup.
CD Pro module on the left, Elso's clock in the middle & power supply for Elso's clock on the right. Thanks Elso for the computer tip |
#48 | |
diyAudio Moderator Emeritus
Can you post your schematic that you are using for your power supply for the cdpro II? I am in the process of planning out a cdpro II project, and I am not sure what to use for the power supply. -- Brian |
#49 |
Brain,
I bought my set from Robert of Ahfart audio in Singapore. He supplied the PCB & parts for the power supply as well. So, not sure whether I can give it to you. However, the schematic is nearly identical to these ones I found on the net : |
#50 |
for the 5V & 9V supply
| Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. | Julien_M | Swap Meet | 5 | 25th January 2009 12:03 AM |
| One clock for CDM12 Pro2 and Nos Dac TDA1545 | gochtoni_toni | Digital Line Level | 28 | 28th November 2007 12:31 AM |
| PCM1794 DAC and CD pro2 clock | galouche | Digital Source | 0 | 9th July 2007 11:00 PM |
| 33.86 Mhz clock on CD-Pro2 | Peter Daniel | Digital Source | 3 | 25th October 2005 11:12 PM |
| Dac with external clock how and why?? | kimschips | Digital Source | 3 | 9th August 2005 11:19 AM |
| Page generated in 0.11044 seconds (70.65% PHP - 29.35% MySQL) with 11 queries |
