| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#31 |
joeling39
Hi, where did u bought the CDPRO2 from? locally or directly from daisy? and how much? i have lost ur email address..pls email me offline..thanks. tone. |
#32 |
Account Disabled
I am sorry Elso and Guido
The reason why the SAA7324 fail with your clocks is this: Your clocks give out a 5 V signal but the SAA7324 is a 3.3 V chip. (Absolute maximum rating for input signals are: 3.6 V)... (See datasheet from above link). This and other 3.3V chips will be destroyed with the KWAK clock even if correctly mounted........ And there is really no way of attenuating the clock signal without degrading the jitter performance on this type of standard CMOS oscillator. Good luck guys .. ;o) |
#33 | |
"when correctly built and mounted - the kwakclock sounds better than the lcaudio xo2 clock"...... |
#34 |
Banned
Hi Lcaudio,
Don't be sorry, thanks for the hint. May I suggest using the KWAK-CLOCK in this particular case with +/-3.3V supplies? This can simply be done by changing two resistors: Make R5 8k66 and R8 12k. All other values remain the same. Best check the supply voltages before connecting the clock to this sensitive chip. Except the one failure in this thread, possibly due to connecting a clock to pin 17 instead of pin 16, I have never heard of any failures. |
#35 | |
Banned
The KWAK-CLOCK is NOT a standard CMOS oscillator! |
#36 |
Account Disabled
Not a very surprising statement coming from you
#37 | |
Banned
It is a fact: there is no CMOS oscillator in my clock!! 999 posts, I can't believe it myself
#38 |
Account Disabled
Sorry i was a little fast on the trigger. You are right!
I confused your clock for another design sent to me a few days ago, and that one was just a simple CMOS can on a PCB. I will check it's name and post here later. I searched the web for your design, and it seems to be OK. |
#39 |
#40 | |
Destroyed: I doubt, at least, when series resistance is used (what i do) as the clock input very likely has ESD protection diodes, able to handle 10mA, if my memory serves me right (I think that chip was still made in Philips C075 process) Anyhow, we should respect the voltages thanks |
| Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. | Julien_M | Swap Meet | 5 | 25th January 2009 12:03 AM |
| One clock for CDM12 Pro2 and Nos Dac TDA1545 | gochtoni_toni | Digital Line Level | 28 | 28th November 2007 12:31 AM |
| PCM1794 DAC and CD pro2 clock | galouche | Digital Source | 0 | 9th July 2007 11:00 PM |
| 33.86 Mhz clock on CD-Pro2 | Peter Daniel | Digital Source | 3 | 25th October 2005 11:12 PM |
| Dac with external clock how and why?? | kimschips | Digital Source | 3 | 9th August 2005 11:19 AM |
| Page generated in 0.12757 seconds (73.12% PHP - 26.88% MySQL) with 11 queries |
