Go Back   Home > Forums > Source & Line > Digital Source
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 7th July 2003, 09:34 AM   #11
kenev is offline kenev
kenev's Avatar
Thanks all for your input.
I've made that modification. I don't remember what pin is the right one but this is critical. One of my SAA7324 died in this experiment so take care, the chip is very sensitive.
That's exactly what I' m afraid of about intervening in such a compact, delicate and with sensitive parts unit as the CD-PRO2.
Lupulroz,
Since, from what you posted, I understand that you have modified quite a large number of CD-PRO2 units, can you tell us, from your experience, some useful precaution and modification tips for disconnecting the internal crystal and attaching an external oscillator? I have seen that there are a lot of diyAudio forum members that have already built a CD-PRO2 based player and I guess that some of them would like to try the "clock upgrade". Any sharing of your experience would be useful.
By the way, my most recent measurements on a Kwak clock showed horrible results.
Guido,
Do I sense a strong controversy here? "Horrible" is such a grave word to describe. Could you elaborate on this?
Regarding crystal frequency, I quote from the SAA7324 data sheet:
Typical oscillation frequencies required are 8.4672, 16.9344 or 33.8688 MHz depending on the internal clock settings used and whether or not the clock multiplier is enabled.
How can someone check what is the frequency used in the unit he has in hand?
Best regards to all,
Evangelos
Old 7th July 2003, 10:00 AM   #12
Banned
Send a message via Yahoo to Elso Kwak
Smile External clock
Hi Evangelos,
The datasheet for the SAA7324 can be downloaded here:
http://www.semiconductors.philips.co...7324H_M2B.html
It clearly shows that the CRIN is pin16.
As for your last question the frequency of the crystal is usually printed on it. I presume the crystal is located very near pin 16. The crystal looks like a flattened oval metal cylinder, couldn't miss it.
Hope this helps.
Old 7th July 2003, 10:38 AM   #13
kenev's Avatar
Hi Elso,
Thanks for the input.
I had already the datasheet for the SAA7324.
My question was mainly of an informative and practical nature regarding this modification: if someone has already done this, I would like him to share his experience on such a delicate (IMO) "surgery". Also, his opinion on whether this is worth trying, relying on the benefits of this modification.
Anyway, thank you.
Old 7th July 2003, 10:44 AM   #14
Default Re: Re: Re: External clock to CD-PRO2
Originally posted by jean-paul
Hi Guido, horrible in what sense ? Jitter, waveform ? I heard/read quite some good responses on Elso's clock.
I measured the spectral response. It contains loads of RF (FM radio stations and others), but even worse, mixed products of harmonics of the mains at (only) -35 dB.
I did not measure jitter, but the spectral response needs to be cleaned up first.
I measured other clocks as well (LC audio, my own and the HP reference clock), as well as the set up, which was clean to -80dB.
I will perform jitter measurements once I have my HP53310A modulation domain analyser up and running.
If someone has a Trichord and an Audiocom available, I'd be willing to measure these as well, I am not wanting to pay for these expensive things
all the best,
Guido Tent
www.Tentlabs.com
Old 7th July 2003, 10:48 AM   #15
Guido,
Evangelos [/B]
Hi
The spectral content should be absolutely clean, at least down to -100dB from the carier, respecting some phase noise closeby.
So far, I can measure down to 80 dB, but I am setting up experiments to go deeper.
Jitter measurements (in the time domain) will follow
best regards
Guido
Guido Tent
www.Tentlabs.com
Old 7th July 2003, 03:28 PM   #16
joeling39's Avatar
Default CD Pro clock
I have been toying with the CD-Pro 2 unit for a while. In stock form, it is not as good as my modified Theta Jade. However, I am really keen to try a new clock on the unit.
Problem with the above is that I can't figure out which is the crystal. After some enlightening posts here. My guess is that the crystal freq is 8.4672MHz. I have attached a picture of where I think the relevant elements of the orginal clock configuration is. Please take a look & comment if it is accurate.
Joe Ling
Old 7th July 2003, 03:30 PM   #17
joeling39's Avatar
Another picture
Old 7th July 2003, 03:41 PM   #18
Banned
Lightbulb Crystal???
Hi Joe,
This looks more like a SMT crystal-oscillator to me, just as in the Sony SCD-1 or 777ES. Very difficult to remove!
Best done VERY carefully with a hot air gun.
Were some posts on AA on this issue.
Old 7th July 2003, 03:49 PM   #19
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
What about just cutting traces, insted of removing?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 7th July 2003, 03:50 PM   #20
joeling39's Avatar
Elso,
Thanks for the info. You clock resides in my Marantz CD63KI & is still functioning perfectly after all this while (maybe more than 1 year already).
Regards.
Joe Ling
Thread Tools
Philips Cd-Pro2 player/transport w/ tent labs XO3 clock - $1000 o.b.o. Julien_M Swap Meet 5 25th January 2009 12:03 AM
One clock for CDM12 Pro2 and Nos Dac TDA1545 gochtoni_toni Digital Line Level 28 28th November 2007 12:31 AM
PCM1794 DAC and CD pro2 clock galouche Digital Source 0 9th July 2007 11:00 PM
33.86 Mhz clock on CD-Pro2 Peter Daniel Digital Source 3 25th October 2005 11:12 PM
Dac with external clock how and why?? kimschips Digital Source 3 9th August 2005 11:19 AM
Page generated in 0.35439706 seconds (69.88% PHP - 30.12% MySQL) with 11 queries
Copyright ©1999-2009 diyAudio
