Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 14th August 2010, 02:06 PM   #1
Brit01 is offline Brit01  United Kingdom
Default Rotel RCD 965BX - upgrades?
Has anyone made upgrades/mods to this model of Rotel CDP?
How can improvements be made to this one?
I'm usually in the valve posts, this is new world to me.
Old 15th August 2010, 06:02 AM   #2
Mooly's Avatar
Not familiar with this player, however subtle (but to a music lover huge) gains might be possible by looking to swap the op amps in the analogue output stages.
So what's in there ? are they NE5534's or NE5532's
A simulation free zone. Design it, build it, test it.
Old 15th August 2010, 07:14 AM   #3
awpagan is offline awpagan  Australia
It has been moded
diyAudio - Search Results
Indecision makes the world gone round.
Maybe
Old 15th August 2010, 10:18 AM   #4
I think the 965Bx is built like the other 855, 865, 955, etc machines but with an extra pcb holding the clock and O/P stage, and possibly the 7310 chip instead of the old 7210 - if so, the same basic upgrades apply - I'm doing a 955Ax now with recaps, bipasses, transport damping, NOS, clock, shunt reg p/supplies and D1 o/p stage - transformers in external box - next stage involves reclocking of I2S, DEM, etc as per EC Design techniques and possibly an optional valve buffered volume control - I do expect good results.
This player uses the standard Phillips
... jh
Old 15th August 2010, 10:23 AM   #5
Mooly's Avatar
Originally Posted by awpagan View Post
It has been moded
Don't understand
The link doesn't go anywhere either.
Old 15th August 2010, 07:59 PM   #6
RIP
The 965BX uses a CDM4 and a bitstream dac chip. I had the LE Discrete model for a couple years. It's great used as a transport, lackluster performance compared to what's out there today, IMHO. I put a Tent Clock in it and it made it edgier,took it out.
Old 15th August 2010, 08:25 PM   #7
Yeah Bill, the full series of upgrades is worth while but it's quite a bit of effort - interesting project.
Brit, there are a cuple of old threads about this player here and a lot of the digital upgrades of the giant Marantz 63 thread apply to this player, too (TeddyRegs power supplies, etc) and the long running "Ultimate 1541A Nos dac ..." thread has a good collection of mods, data and other explanations about the inner workings of the 1541A dac chip.
... jh
Old 15th August 2010, 11:46 PM   #8
amc184 is offline amc184  New Zealand
amc184's Avatar
No, the 965BX uses a single board (as does the 865BX). Unfortunately, unlike the 865 and 965AX, you can't convert this player back from bitstream SAA7323GP to multibit TDA1541A.
There are three modifications that I would consider doing:
- Upgrade the single opamp in each channel of the output stage (U114 and U115). Candidates could be the OPA604, OPA134, LME49710 and many others. It's probably best to install a DIP socket and get a variety to try, as this often comes down to personal taste.
- Remove the SAA7220 if you're not using the digital output. The SAA7220 in this CDP is used for generating a SPDIF signal only, and this IC is very power hungry. It will propagate noise into its power supply, and this noise will contaminate parts of the power supply for the rest of the player.
- Install a low jitter clock. Every CD player will benefit from a good low jitter clock.
Overall though, I don't think this is a very promising player. It uses a good transport, but it is hobbled by the poor quality first generation bitstream DAC it uses. I think the best use of this player would be to install a completely new filter, DAC and output stage.
Old 17th August 2010, 07:13 PM   #9
Thxs for the advice guys.
I'll do some research into this. No I'm not using the dig output.
Rotel RCD 965BX stops playing after several tracks jnewbold Digital Source 4 7th June 2010 10:50 AM
Rotel RCD-965BX CD Player,Worthwhile mods? fergs1 Digital Source 9 6th August 2008 05:42 AM
Upgrades to my Rotel RCD-930AX CD Player Drew Digital Source 8 1st July 2008 12:06 AM
Rotel RCD-965BX Schematic Needed Algar_emi Solid State 1 7th September 2004 03:06 PM
rcd-965bx problem tonitze Digital Source 4 4th June 2003 04:18 PM
Page generated in 0.10710 seconds (77.24% PHP - 22.76% MySQL) with 10 queries
