Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th August 2010, 08:44 PM   #1
Maxxtr0 is offline Maxxtr0  Germany
Default CD Player canīt read CD before 5mins. on-time
Hello everyone!
I have a strange problem with my moddified Denon CD-Player:
When I turn it on in the morning it starts to turn the Disc, and reads, and reads... and finally says that there are 0 Tracks on that CD.
If I leave it powered on for about 5 minutes and re-insert the CD after that Time it normaly reads it.
I changed the oscillator with a Tentlab X0, but I don not really think that there is a problem, because while moddifying it, I realized that the spindle motor and the focus go nut if the clock doesnīt work!
And that isnīt appearing now.
Where could the problem be?
Old 8th August 2010, 09:23 PM   #2
Are you sure the new 'clock' is running at the correct frequency from 'cold'?
If just a few Hertz out it may be enough to provide timing for the Focus and Spindle drives to function so as not to 'run away' but not quite right.
As the 'clock' warms up it may 'drift' into spec'n and all is ok?
Can you measure the frequency?
"An AudioPhool and Proud of it!!"
Old 8th August 2010, 09:51 PM   #3
georgehifi's Avatar
Send a message via MSN to georgehifi
Try too make the clock powerup a couple of seconds first before the rest of the cdp, I have fixed the same problem like this by doing this.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 9th August 2010, 07:52 PM   #4
Well after a factory reset it seems to work now... but maybe that was just randomness.
If it wonīt work tomorrow morning, how did you manage to start the oscillator before the CDP?
Old 9th August 2010, 09:29 PM   #5
georgehifi's Avatar
!t was powered by it's own supply getting the mains before the power switch which was on 24/7 then power switch powered up the rest of the cdp.
Cheers George
x-meridian, time to toss your cd player? DJNUBZ Digital Source 5 22nd February 2007 03:17 PM
Will Higher End CD Players read CD-r Data Disks? ransom peek Everything Else 1 3rd October 2006 03:32 AM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
CD player doesn't read CDRs Peter Daniel Digital Source 30 9th June 2003 02:44 PM
Page generated in 0.07623 seconds (71.20% PHP - 28.80% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
