Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 3rd August 2010, 12:35 AM   #1
Default Newbie question: Replacing KSS-213c in Audio Aero Prima
Hello all,
I have spent the better part of the last two days reading and learning from your wonderful forum, but am in the need of a little help/guidance.
I have an Audio Aero Prima cd player that uses a Sony based transport (not sure which one and can not get an answer from the manufacturer). What I do know is that it uses a KSS-213C laser assembly.
Over the last couple of months, it has been having increasing difficulty reading discs. Initially CD-Rs and older CD, and now even new CD's can't be read or skips frequently. From what I have read here it sounds as if the laser is failing. With a little internet research I found that the KSS-123 variants are relatively inexpensive and easy to source.
So my question is this: how hard is it the change out the laser assembly? Is it generally plug and play?, or after replacement is there a recalibration process required that is beyond the average DIY? And finally, is it sometimes just easier to replace the whole transport with the laser assembly if you are not experienced the electronic repairs?
Any input is greatly appreciated!!
Old 3rd August 2010, 02:46 PM   #2
RIP
You should replace the entire assy,around 15-20 bucks, and no calibration needed. Be careful not to damage the disc platform on the new spindle motor, they are flimsy and the metal plate can slightly separate from the plastic, causing the disc to wobble. Ask me how I know.
You have the hard part done already, removing the tray. The ribbon cable just pulls out of the connector, it's a friction fit.
Pay attention to the support springs, they are different front to back.
That's all I can remember.
Old 3rd August 2010, 02:51 PM   #3
Thank you so much Bill!!! That is what I suspected from reading older posts. I have ordered the part and will update when its done.
Thanks again!
Old 3rd August 2010, 07:29 PM   #4
RIP
Oh yeah, you will have 1 solder blob to remove from the laser head. The directions should be packed with the unit.
SONY KSS-213C help fastvideo Digital Source 1 30th July 2010 12:38 PM
Help with audio aero dac Condensador Digital Source 0 7th June 2010 10:12 PM
KSS-210A (= KSS-150A Successor) and KSS-212A - what is the main difference? tiefbassuebertr Digital Source 0 12th March 2010 06:06 PM
newbie question - replacing caps xn7 Solid State 14 14th May 2009 08:34 AM
Any Audio Aero MR 2 owners out there? Sam GT Digital Source 0 30th October 2007 02:38 AM
Page generated in 0.08313 seconds (75.20% PHP - 24.80% MySQL) with 11 queries
