Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 22nd July 2010, 05:38 AM   #1
Default Marantz CD94 Help!!!!
Hi Folks,
I am a Marantz CD94 user from South Korea.
Could anyone let me know how much the original value of resistors are?
I blew out my beloved CDP by ridiculous mistakes.
It would be really helpful if anybody shows me close-up photos of resistors to read the value.
Lastly, what section is the resistors in? Powersupply or signal path?
Thank you for your help in advance.
Kim
Old 22nd July 2010, 08:12 AM   #2
2 resistors are pointed on the image!!
I guess the section is output stage related with OP amp, right?
Old 22nd July 2010, 10:38 AM   #3
tonimxp is offline tonimxp  Italy
Hi!Please can tell me how are called on the PCB?
For example C25 or C followed by a number, if I find I can communicate the value of the wiring diagram.
Old 22nd July 2010, 11:38 AM   #4
Hi! Thanks for your reply Tonimxp!
R831,832 are written on the PCB. In addition, I think R801,802 needed to be replaced. Thanks again!
Old 22nd July 2010, 11:53 AM   #5
R831,832 are wrriten on the PCB.
Thanks again!!!
Old 22nd July 2010, 01:15 PM   #6
oshifis is offline oshifis  Hungary
I had the same problem. These resistors are of a few ohm (3.9 ohm if I remember well) fusible that are blowing out by overcurrent. They are connected between the transformer and both AC sides of the rectifier bridges for the +/-12V and +/-13.5V. The blown resistors on your picture do not seem original. They should not show any burning, just go in open circuit when blown. Since I could not find any replacement, I simply bridged (short-circuited) them. No problem so far...
Old 23rd July 2010, 04:01 PM   #7
Default Thanks Oshifis
Thanks for your kind insturction!
I will try the same way as yours if I can not get the replacement.
There is one more question.
You mentioned the value is 3.9 ohm. Please see the attachment.
R832,831 is marked 1 ohm on the service manual.
Which one is right? I am a bit confused.
If it is just a fuse resistor(not affect to voltage change...)
1 or 3.9 ohm both would be fine,right?
(Sorry for ignorance , I am not an expert...)
Old 23rd July 2010, 07:27 PM   #8
tiefbassuebertr's Avatar
go to
Philips CD960 | Owners Manual, Service Manual, Schematics, Free Download | HiFi Engine
to download the Service Manual from Philips CD-960.
The differences between CD960 and this model from Marantz is only the outline.
Various threads already exist concerning this both models:
Help with Philips CD960
CD960 tray problem...
Philips CD-960
Philips CD 960
Non oversampling cd-94 MK1
Looking for Marantz CD-94 schematic
Identifying a CD94 Mk2?
Old 24th July 2010, 12:23 PM   #9
Check my service manual and confirm R832,831 is 1 ohm fusible resistors.
I would check if there are any short on both lines of supply from this two resistors, remove and clean all corroded glue on the circuit board.
Old 24th July 2010, 02:40 PM   #10
Default Thanks!
Many Thanks Tiefbassuebertr and Fastvideo!
Marantz CD94 mk 2 Downundernick Vendor's Bazaar 0 13th July 2010 01:23 PM
Looking for Marantz CD94 PLAY button oshifis Digital Source 1 31st October 2007 04:27 PM
WTB: Marantz CD94 NickC Swap Meet 0 22nd November 2006 07:34 PM
Marantz CD94 or CD99? commstech Digital Source 2 29th July 2004 01:25 AM
Marantz CD94 lucpes Digital Source 1 3rd May 2004 02:10 AM
Page generated in 0.10709 seconds (77.64% PHP - 22.36% MySQL) with 11 queries
