Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old Sony MHC 1600
Old Sony MHC 1600
Old 1st February 2012, 04:24 AM   #21
gmphadte is offline gmphadte  India
STK4232 has a mute pin.
Gajanan Phadte
Old 1st February 2012, 08:22 AM   #22
I missed this one.
The motor of the volume control is driven by LB1639 (IIRC) and the two control logic inputs at pin 1 and 4 are driven by the microcontroller annotated as IC301 on the front board.
Gajanan Phadte
Old 3rd February 2012, 02:38 AM   #23
hoonie is offline hoonie
Hi all,
I also have a MHC-1600 that I used for years in the 90s and as late as 2010 and then packed it into storage. I just tried hooking it up again but there is no sign of power whatsoever. Does anyone know what I can do? Is there a simple fuse I can change?
Old 3rd February 2012, 03:19 AM   #24
If the fuse is blown.
Open the back cover and the top cover. IIRC, there is a fuse on the pcb on which the power connector is fitted.
KEEP THE MAINS CHORD DISCONNECTED ALL THE TIME WHEN THE STEREO IS OPEN.
Gajanan Phadte
Old 13th February 2012, 07:20 PM   #25
Thanks, gmphadte,
It does not seem to be a blown fuse.
Is there anything else I can try. Visually nothing looks broken or burned out.
Thanks for your help.
Old 14th February 2012, 09:28 AM   #26
Now u have to check the power supply and the fuses on the secondary side. The voltages r normally written on the pcb.
I think u better start with soldering the cracked and dry solder points.
Gajanan Phadte
Old Sony MHC 1600Hide this!Advertise here!
Heathkit AA-1600 monkeyboie Solid State 8 30th April 2011 08:05 PM
Sony MHC-RV22 contactbb Everything Else 0 10th August 2008 06:36 AM
Sony MHC-RV22 CD section problem sukhbinder Digital Source 8 23rd July 2008 04:40 PM
MHC 1600 CD drive jefftuba Parts 0 23rd May 2006 11:29 PM
Sony - MHC-1600 Stereo / CD Player Rusty777 Solid State 4 20th March 2005 04:09 PM
