Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 13th July 2010, 07:26 PM   #1
Maxxtr0 is offline Maxxtr0  Germany
Default DIY CD-Player: Component Question
Hello everyone!
I´m not really sure if this belongs here...
On this page there is a "Reciever IC" Andrea Ciuffoli - dac & cd player.
As far as I understood, you have to connect the output of a CD-Decoding IC to "Input". Then you need some kind of input circuit.
But for what do you need a "Reciever IC" or what does it do?
Greetings,
Max
Old 14th July 2010, 11:17 AM   #2
RIP
I can help with basic info but I'm not a digital expert by any stretch.
A cd player generally has no need for a receiver chip as the transport sends a stream of data to the decoder chip that converts the stream into a format that is compatible with the dac chip being used.
Generally, a receiver chip like the CS8416 or others is used in an outboard dac unit to receive data and clock info from an SPDIF stream, and convert it to a format that it's dac chip can use.
SPDIF is strictly a transmission format used solely for interconnection between stand alone digital units using coax cable or toslink. SPDIF is not used in a player, but most players do have an SPDIF ouput that is usually generated by the decoder chip such as SAA7210 and many,many others. Even many players without a digital output have the capability, but the manufacturer has chosen not to include one for cost cutting purposes. You would have to research your decoder chip to see if it is available in your unit. Many older Philips/Magnavox players have the capability, I have several different ones.
I hope I have helped a little.
Old 15th July 2010, 09:53 AM   #3
Hello,
okay, thanks for the information!
Greets,
Max
DIY CD Player with RC, display, 2 drives changer and CD-Text. dxer_87 Digital Source 12 26th November 2010 02:06 PM
which cd-rom drive for diy cd player ? grube47 Digital Source 10 2nd January 2010 09:24 PM
Could someone post a CDROM Controller schematic to DIY the CD ROM to be a CD player? fsclub Digital Source 11 18th December 2006 01:19 PM
Anyone can post some japan website use CD-Rom diy CD player? jelou Digital Source 2 29th May 2004 10:44 AM
How do I use CD-Rom diy meridian 588 CD player and 800 reference CD/DVD player? jelou Digital Source 4 29th April 2004 03:48 AM
Page generated in 0.07970 seconds (71.62% PHP - 28.38% MySQL) with 10 queries
