Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Comments on PCM1794A DAC design
Old 6th September 2010, 01:51 AM   #51
sendler is offline sendler  United States
Default Mono mode
I'm interested in trying my Gigaworks big dac boards with PCM1798 with a passive transformer I/V and want to use mono mode to increase the available output level. Where did you find the info on the output connections showing L+ tied parallel to R-. The PCM1794a data sheet doesn't show any info on a direct parallel connection for mono mode.
Scott
Old 8th September 2010, 07:58 AM   #52
novec is offline novec  Norway
novec's Avatar
Send a message via MSN to novec
The direct parallel is taken from an Analog Devices datasheet (can't remember which one), and has been confirmed by TI on another user's request. And no, I can't remember where I read that, either :-)
The reason TI hasn't mentioned it in their datasheet is because they consider the summed output current too high for their recommended output circuits, but it might be just what the doctor ordered for your application.
Old 8th September 2010, 10:34 AM   #53
Default Dac Final
I did find another web page evaluating dac chips in mono mode.
DAC Final
Scott
Old 9th September 2010, 01:45 PM   #54
novec's Avatar
Nice to get another confirmation of the connections. I'm not too worried about their test results, though. First of all, the PCM1794A is not designed for passive I/V. Secondly, it (and probably the others, to a varying degree) is sensitive to PCB layout, like bypass caps, ground scheme and so on. DIP adapter and proto boards aren't exactly optimal for sensitive electronics... Even so, tests like these are always appreciated!
I haven't had the time to work on my DACs this summer, but it looks like my schedule is opening up a bit. I'll keep you posted as I go along!
Old 4th June 2012, 07:58 PM   #55
xslavic is offline xslavic  Moldova
Default Hi
hello
im trying to build a Pcm1794a in dual mono,can someone tell me if i should use a resistor before opamp input ?the currents were summed + 100ohm to ground
ill use something like opa2227
here is the schematics PCM1794 dual mono i/v converter - conversion - stage :
ill use 2sc2362 instead of BC547 /SA970 / 2 SC2240
Comments on PCM1794A DAC designHide this!Advertise here!
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
Any comments on this design? icebear Tubes / Valves 23 19th May 2009 04:07 PM
Comments on this design? G Tubes / Valves 0 16th October 2003 05:09 PM
