Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Comments on PCM1794A DAC design
Old 26th June 2010, 08:06 PM   #21
SoNic_real_one is offline SoNic_real_one  United States
Originally Posted by abraxalito View Post
Take a look by all means, but don't try that at home. This is quite a good example of how not to do a DAC output stage - in particular the decoupling. Are all those thick (power) traces ground fills?
Board looks different, schematic is just that - schematic...
Old 28th June 2010, 09:07 AM   #22
novec is offline novec  Norway
novec's Avatar
Send a message via MSN to novec
Are you really sure sensitive analog circuits are going to be better off with multiple built-in 2MHz oscillators? Especially as each reg has its own and they won't be synchronised.
Sure? Never :-) But I'm trusting Pierre on this. If he says it's good, it's good enough for me. And the specs do look nice.
I'll start off with two DAC boards, with and without SRC, and shuffle things around a bit to be able to experiment with Iref resistors and PSU resistors and caps. They'll still be separate boards so I can test both zapfilter and LM4562 output stage.
If I keep the PSU resistors for each rail, how do I decide on the values? DIR draws 2x 8.3 mA, SRC draws 2 + 66 mA. DAC Idd draws 23-45 mA depending on sampling frequency and ~35 mA Icc. There's no separate power data for the three Vcc rails.
Old 28th June 2010, 09:26 PM   #23
novec's Avatar
Ok, I'm having a little difficulty understanding the Denon circuit... I can see that the first six opamps are the regular I/V and summing circuits, and IC406-1 single ends it all. But what's IC406-2 and all the transistors for?
Old 29th June 2010, 12:33 AM   #24
abraxalito is online now abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
IC406-2 looks to be a switchable gain stage (0dB, 6dB) but I can't think why its needed. The transistors on the output side (TR402/3) are for pop/click suppression on power up/down or output muting (which is the same thing). Notice they're the 'wrong' way around - I dimly recall that a transistor connected in such a way has a lower saturation voltage.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 29th June 2010, 12:36 AM   #25
abraxalito's Avatar
Yes they do - how clever of them to limit the specified noise bandwidth to 100kHz when that little charge pump runs at 2MHz
Old 29th June 2010, 01:34 AM   #26
jcx is offline jcx  United States
does the player include HDCD decoding? - the standard requires gain change
Old 29th June 2010, 03:13 AM   #27
Hisatugo is offline Hisatugo  Brazil
Hisatugo's Avatar
Hi Guys...
I'm just keeping an eye on this thread... my design includes some complicators... I decided to regulate each voltage rail separately.. +5Va, +3V3 digital, +5VaR, +5VaL... using LT1763-xV, and analog outs are via OPamp.. LME49722 (4562 version2)...
I was thinking about hires sources of signal: maybe SRC is just a jitter reclocker than anything... is not 24/48K enough? If so, I would get SRC out and put a PMD100 in the circuit, the clock is supplied like "the Flea" and is near.
just thoughts... not to disturb your thread. :-)
About Denon: yes, 2930 and family has HDCD... that output is for gain purpose of HDCD lower out. Mine is a little different as 2930 uses PCM1791.
But the DAC project is intended to be used with SD card player.
Regards.
Hisatugo.
I love DIY. And love electronics also. But I refresh me everyday that my real passion is MUSIC.
Old 29th June 2010, 03:34 AM   #28
Hisatugo's Avatar
Smile taking part of it...
to who may interest...
Old 29th June 2010, 08:16 AM   #29
novec's Avatar
M'kay. Just wanted to make sure I didn't have to mess with it.
Sulplise, sulplise
Originally Posted by Hisatugo View Post
Hi Guys...
I was considering the same, but decided it was too overkill, even for me... With ten channels, that's 20 more regulators.
I'll want to try 192 kHz upsampling with the SRC, but its main function is reclocking. But as stated earlier, I'm suspecting (and hoping) the Lynx AES16 source clock is clean enough to skip the whole SRC.
This kind of "disturbance" is exactly what makes diyAudio forums great
Old 29th June 2010, 03:42 PM   #30
That's exactly what it is.
Comments on PCM1794A DAC designHide this!Advertise here!
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
Any comments on this design? icebear Tubes / Valves 23 19th May 2009 04:07 PM
Comments on this design? G Tubes / Valves 0 16th October 2003 05:09 PM
