Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Comments on PCM1794A DAC design
Old 24th June 2010, 06:49 PM   #11
novec is offline novec  Norway
novec's Avatar
Send a message via MSN to novec
SoNic_real_one: Like awpagan says, increasing the Iref resistor would decrease Iref and thus Iout to a level the zaps can handle. And I am annoyingly aware that'll increase S/N at the same ratio... Right now I'm torn between accepting that fact and using the zaps that I know and like, and have paid good money for, or start working on another output that may or may not be better.
jcx: Your solution looks very interesting, the only caveat is the dreaded T&M - time and money. Do you have any idea when you might have a working and tested circuit i can "borrow"? Despite being stubborn and annoying, I am open to other solutions, as long as they're better ;-)
Old 24th June 2010, 11:05 PM   #12
SoNic_real_one is offline SoNic_real_one  United States
You said 'Iref', not 'Iref resistor', just making an observation
Personally I think that good OpAmps are all you need for a good DAC.
Old 25th June 2010, 01:33 AM   #13
novec's Avatar
That's me - writing half a sentence and thinking the rest
I tend to think a discrete output stage has the potential of being the best, but has a greater potential of being a complete failure. The only opamps I have any kind of experience with are the LM4562, which have fared pretty well with the PCM1794 for a friend of mine. And as far as good goes, those tend to come at a price, and I need 10+ channels for five channel active XO. But let's not worry about that just yet...
jcx: I'll start ordering samples right away! With 50-ish opamps it's gonna take a while
Old 25th June 2010, 04:25 AM   #14
jcx is online now jcx  United States
I suspect the ADA4898 in the single op amp transimpedance I/V per the DAC app note will be very good even at the PCM 1794 current levels - I should think a significant improvement over the 5534 - the low Vin noise allows the noise gain input mod that shaves a little off the peak error by directly shunting switching glitch energy to gnd
the ADA4898 multi-tanh linearizes the input to 1 ppm gm change at ~ 4 mV diff Vin
the multiloop Hawksford I/V would be a beast - I'd probably use a composite for the final follower to reduce its errors too
but op amp expense is only the start - you will be spending $5-10 ea for bulk metal foil resistors - its the only right thing to do when the active devcie distortion is driven so low
Old 25th June 2010, 11:44 AM   #15
novec's Avatar
Ok, now you're getting me seriously interested... Potentially broke, but interested... Where do I sign up? :-)
Do you have a rough estimate on when you'll have tested the Hawksford with ADA4898? I'm leaning towards making a simple opamp output for now, and go for a better one once I've played with the DACs some more. I'm still not sure whether the SRC will be necessary with the Lynx AES16 as the only source.
Would you recommend ADA4898 for summing too, or just I/V? after a lot of back and forth I've decided to go single ended.
Old 25th June 2010, 02:24 PM   #16
I did have a great experience with LM4562 in summing/filter, so good that I replaced all the OpAmps in my Denon AVR3805 receiver, DVD2930 universal player, Toshiba universal player (SMD's) and even the I/V stage in a Phillips CD 374 (8DIP) with those...
I am interested in the ADA4898, as a matter of fact I am waiting for a couple samples right now. But in Denon's I have PCM1791A, that are voltage-output.
But already the LM4562 is so good that I cannot envision making a big improvement - but who knows?
Old 25th June 2010, 03:37 PM   #17
novec's Avatar
I actually have some LM4562 DIPs laying around, so I guess the first batch will use them Do you have your circuit (with values) handy?
Old 25th June 2010, 06:17 PM   #18
Use the one from the reference PDF page 20,21 - resistor values are ok for 4562. Just ditch the 22pF capacitors, 4562 is internally compensated (unity gain stable).
You also can take a look at how it is done for PCM1792 in Denon DVD-5910...
Old 26th June 2010, 02:15 AM   #19
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Take a look by all means, but don't try that at home. This is quite a good example of how not to do a DAC output stage - in particular the decoupling. Are all those thick (power) traces ground fills?
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 26th June 2010, 03:22 AM   #20
abraxalito's Avatar
... considering the awesome REG113...
I'd not come across that part before, certainly does look high performance. But then, buried deep in the datasheet I read this :
The REG113 uses an internal charge pump to develop an
internal supply voltage sufficient to drive the gate of the
DMOS pass element above VIN. The charge-pump switching
noise (nominal switching frequency = 2MHz) is not measur-
able at the output of the regulator over most values of IOUT
and COUT.
Are you really sure sensitive analog circuits are going to be better off with multiple built-in 2MHz oscillators? Especially as each reg has its own and they won't be synchronised.
Comments on PCM1794A DAC designHide this!Advertise here!
Micro DIR9001 + PCM1794A DAC theAnonymous1 Digital Source 88 14th June 2010 09:01 AM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
FS: Twistedpear PCM1794A DAC Board pftrvlr Swap Meet 2 18th April 2010 03:52 PM
Any comments on this design? icebear Tubes / Valves 23 19th May 2009 04:07 PM
Comments on this design? G Tubes / Valves 0 16th October 2003 05:09 PM
