| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hey Guys,
my beloved Luxman CD player DZ-03 has started skipping on various tracks, mostly in the beginning of a CD though. Would any of you be in possesion of the service manual for this CD player?? If so I would be really greatful. (waiting with my fingers crossed) ![]() ![]() .
#2 |
Don't have the manual, but I know the unit. Odds are that you have one of two platter spinning problems. Either a)the platter motor simply needs a spray of silicone-based lub up the back end to dislodge & prevent carbon build-up on the commutator, and/or b)the thrust bearing plate that presses the disc clamp against the platter has a hole worn into it, which would need to be sanded down to flat again, polished & greased(unless it has a magnetic clamper that uses no thrust bearing, in which case, it is almost certainly the first fault). The KSS152A laser it uses rarely goes bad in any way other than failing to play certain or all discs, so it is not likely a laser problem.
#3 |
Thanks, Stephen.
It has a magnetic clamp, so Ill try to exchange the disc-motor first. Would still like the manual though, just to do a complete readjustment of the servo :-) |
#4 |
Update:
New disc-motor didnt change anything, neither did increasing the laser-gain a little, so I just ordered a new KSS152A. Still trying to get hold of the service manual though, so if anyone???????? :-) |
#5 |
ask there:
info@schaltungsdienst.de Schaltungsdienst Lange oHG Zehrensdorfer Str. 11 D-12277 Berlin-Marienfelde Tel.: ++49 (0) 30 / 723 81-3 Fax: ++49 (0) 30 / 723 81-500 Impressum: SDL Digitaler Buchdruck |
#6 |
Thank you, DeepBass, but no luck, they dont have it. Anyone else please :-)
#7 |
Small update.
No luck yet, replaced both laser and spindlemotor, and the error is still the same. Found out though, that the DZ-03 is identical to the D-103U except for some cabinet parts. Would any of you happen to have the service manual for the D-103U???? |
#8 |
I think I have it...will check and report here for couple of hours.
Edit: link to free service manual http://elektrotanya.com/luxman_d103u.pdf/download.html
Non mai abbastanza... Last edited by aparatusonitus; 8th July 2010 at 03:35 PM. |
#9 | |
Service manuals and owner's manuals (DZ-03 service manual) here additional URLs for you: LUXMAN-D103u (D-103u) Luxman DZ-112 e DZ-03 (valvolare) (DZ-03) ALPINE/LUXMAN CDvC[D-103̎dl ApC/bNX} (Luxman/Alpine D-103, complete different) |
#10 |
Thanks alot Guys :-)
Will keep you posted on whats happening, and what the error was (if I find it) :-) |
| Quiescent Current Luxman M-03 | Weide | Solid State | 5 | 7th January 2012 10:33 AM |
| Sansui CDX-311 and Luxman DZ-111: worth it? | Malefoda | Digital Source | 4 | 17th November 2009 05:23 PM |
| My Luxman M-03 can not work | guan_216 | Solid State | 5 | 7th May 2006 02:20 PM |
| It's something wrong with my Luxman M-03 | guan_216 | Solid State | 0 | 7th May 2006 02:18 AM |
| Page generated in 0.10810 seconds (74.62% PHP - 25.38% MySQL) with 11 queries |
