Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
RF Attenuators = Jitter Reducers
View Poll Results: Do you have a SPDIF transformer in your Digital Device
Yes 40 71.43%
No 16 28.57%
Voters: 56. You may not vote on this poll
Closed Thread
Old 3rd November 2010, 04:32 PM   #301
jkeny is offline jkeny  Ireland
Banned
Originally Posted by Joseph K View Post
Thorsten - yes, I had followed the thread, and know what are You talking about.
Also what Sy is talking about. That is why I wanted to post these few shots, to show that "at the source", at the input of his DAC providing his results, there are real differences in the incoming SPDIF data.
And this thread is about characterization of the SPDIF transmitter unit, that is, the resulting SPDIF stream, not the DAC output.
One can just not guess what will be connected to this stream.
If somebody is interested, I'm more than willing to explain more about these graphs. It's fun to see easily all the up to now "suspected" effects - being just that, effects existing really..
Guys, I suspected as much - that testing the analogue waveform is somewhat fruitless & I had said as much in another thread that was promptly closed down after SPDIF scope shots were rejected
http://www.diyaudio.com/forums/every...-not-show.html
I'm interested in your graphs George, please explain!
Old 3rd November 2010, 04:48 PM   #302
Banned
Originally Posted by ThorstenL View Post
In Sy's case the DAC being a Behringer DCX2496 DSP based crossover with a nice Cirrus Logic ASRC on the input to propperly louse things up for good measure.
Ciao T
Yes an ASRC will nicely mess thing up - even the sonics in a lot of cases - I have posted about this elsewhere!
Old 3rd November 2010, 05:46 PM   #303
Joseph K is offline Joseph K  Hungary
The pivotal point of these jitter tests is the measurement of the Time Interval Error (TIE) value.
A good short description could be found, for example, here:
Jitter & Wander Tutorial
A short definition could be this -
"The time difference between a real clock and an ideal uniform time scale, after a time interval following perfect synchronization between the clock and the scale. "
That is, the scope is set to collect a huge amount of data points. (10 -200 million points). This memory should be also very fast - we are putting in data at the maximum sample rate. In this case, at each 25psecs. But it can be 100 psecs as well, will work very good anyway.
Then the run is stopped, and the data edges are searched for. An algorithm looks at the data structure, defines the UI, and from there recovers the frequency of the fundamental clock embedded in the data.
When this ideal fundamental clock is reconstructed then each individual edge is examined again, and from it's actual crossing time value the corresponding ideal value is subtracted. The resulting difference is what is called TIE.
All this is nicely illustrated in the link above.
As it is shown there, one can depict a time trend graph, showing how these error values are evolving for each consecutive data transition edge.
This is what the TIE time trend plots are showing.
Also an FFT can executed on these values, to show their behaviour in the frequency domain. These are the phase noise plots shown here.
Then histograms can be collected, for all transitions, to see their statistical distribution. From this then ISI, BER, Rj Pj DDj etc values can be extracted.
Exactly these statistical parameters are the famous "numbers" what we all are after.
For me, the real value is in being able to see how the TIE behaves in time..
Ciao, George
Old 3rd November 2010, 06:09 PM   #304
guido is offline guido  Netherlands
guido's Avatar
Bit offtopic. Got an old timing analyser for this. Starts a counter at an edge and stops it on the next. Counter value is used as index into a memory location (number of counter values is equal to number of memory locations). Before the counter is started, a configurable delay can be set. So you can `zoom in`
So the memory value is read, increased by one and placed back in the memory. Then do this some million times, and then display the memory contents as histogram on the display. Gives you a nice histogram and an indication of jitter. Can see the difference between a good and a bad clock, but the resolution is not good enough to see difference between good and really good..
But you can also measure more than one delta, e.g. the output of an early 1bit dac. Gives you 6 histograms or so.
GuidoB
Old 3rd November 2010, 06:42 PM   #305
Guido,
Similar to your analyzer is the tipical TDC, time to digital converter, which is used a lot in physics.
Time to digital converter - Wikipedia, the free encyclopedia
And yes, it can be used to collect the same histograms, like the TIE histograms here. We used these to measure jitter in our experiments a lot of time. Typically these have 45 psec resolution, that is the finest binning.
But there is an important point: seemingly also the scope would have a similar resolution, 25 - 40 - 100 psecs. But. An interpolating algorithm is used, so the crossing time can be extrapolated by a much better precision.
The higher level scopes are good down to 1psec jitter resolution, the best ones are having like 500 femtosec jitter noise floor.
I have seen the built in 50psec rise time square signal generator's jitter: it was gaussian, 1sigma was 1.5psec. In the above histograms it would be a thin line.
Another point: a TDC like instrument collects only histograms, you loose the "private" information of the individual edges, so no time trend reconstruction. Also no FFT of it, no phase noise plots.
Again: a TDC has to be started / stopped at each time. That is, triggered. Also this procedure, producing the trigger, is producing it's own jitter contribution. Not by accident the discriminators used for it are a topic on it's own.
Also conventional scope "eye diagrams" are having the scope trigger jitter included.
In the plots above this is not existent: there was only one trigger at the beginning.
Ciao, George
Old 3rd November 2010, 06:59 PM   #306
Banned
Thanks George,
So in looking at the TIE spectrum plots can I ask some questions:
- the close in phase noise is different between the old & new - is this purely a reflection of the Q of the crystal & the PS i/f noise - any other factors?
- what is the jitter around the 1.5mHz area possibly related to?
- Are the differences between the units more than would be expected due to manufacturing tolerances?
Old 3rd November 2010, 07:00 PM   #307
I have mentioned the scope shot done by jkeny in this thread:
M2TECH Hiface USB->SPDIF 24/192Khz asynch
Compare this to the recovered TIE trend plots here..
File Type: jpg 3.3V from HiFace - Laptop Dell supply.jpg (275.5 KB, 146 views)
Old 3rd November 2010, 07:02 PM   #308
Now, because of the correlation, I am quite sure that removing that power supply noise component from the clock, the recovered jitter would be much different..
Old 3rd November 2010, 07:06 PM   #309
Banned
Yes, George, that's what I found & have been saying here - it's also audibly better - but then why would anybody believe me?
Old 3rd November 2010, 07:12 PM   #310
~1.5MHz.. also I was thinking of that.
The spdif bit rate at 44.1khz is 2.8224 MHz. Half of it is 1.4112 MHz, and that is the strongest frequency line if you look at an SPDIF data stream on a spectrum analyzer.
So probably this is the jitter caused by clocking out the data..
The tall line at the bottom of the spectrum is the ~80kHz power supply noise.
Closed Thread
RF Attenuators = Jitter ReducersHide this!Advertise here!
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
Attenuators stven Parts 0 12th January 2009 03:05 AM
Attenuators ------ Please Help soundbadger Tubes / Valves 5 13th February 2008 04:19 PM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
About Attenuators leiade Solid State 8 3rd November 2002 08:54 PM
