Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
View Poll Results: Do you have a SPDIF transformer in your Digital Device
Yes 40 71.43%
No 16 28.57%
Voters: 56. You may not vote on this poll
Closed Thread
Old 21st June 2010, 03:52 AM   #21
For the Krell owning types.
Old 21st June 2010, 08:05 AM   #22
regal is offline regal  United States
Originally Posted by wakibaki View Post
jkeny
Does a capacitor pass AC but not DC? It's a FACT. .
it depends , in the real world we don't deal with DC, there is always some amount of sub 1hz frequency that passes thru caps and presents itself as DC (for all practical purpose.) And all caps have leakage.
I guess what I am saying is in text books things are cut and dry, but after you close the books and start working you will learn its not all black and white in the real world. If you keep a closed mind you will never grow as an engineer.
Just because an SPDIF is terminated at 75 ohms on the receiving end doesn't make it perfect. I think you need to spend some time on the bench with a scope.
Old 21st June 2010, 08:45 AM   #23
jkeny is offline jkeny  Ireland
Banned
Originally Posted by abraxalito View Post
Curious - how do you know what jitter sounds like? Have you managed to isolate the effects of jitter so you're sure you're hearing it on its own? If so, I'd like to know how you did this.
I modified a Hiface unit & the only change was to provide a clean clock supply - huge difference in sound - it agreed with all others who report the same - it agrees with the various descriptions of the sound of jitter that I've read - you even seem to know this yourself in your soundstage statement below - what else do you want to attribute this one change to?
My guess here is its also affecting the RF intermodulation, not just the jitter. I get 'slight edge and sibilance' from not paying attention to RF issues. I do agree that jitter affects the definition of soundstage images. So I hypothesise that you're reducing two effects here, not just one.
Oh great, so you agree that it's reducing jitter & NOW you have another effect that you are attributing to it using guesswork. I've already pointed out that there are measurements of the reduction in reflections - why do you have to GUESS that something else is at work?
Old 21st June 2010, 08:49 AM   #24
Banned
Originally Posted by rfbrw View Post
Oh yeah baby, it's bigger & industrial looking, so it must be better - I'll have two of them & hopefully they are very expensive so then I'll know that they are better than the $12 ones & can tell everybody so
Old 21st June 2010, 09:10 AM   #25
Banned
Wakibaki,
I'm not suggesting that anybody wilfully did anything - just mistakenly made the same assumption you do & said "there's a 75R in there so our termination is perfect" - as Regal says a bit of measurement may reveal otherwise. Have you ignored the TDR plots I've been mentioning throughout all this which shows reflections in a "properly terminated" system & how these were measurably reduced when an attenuator was used? This termination was done according to the application note in the TI DIT4192 datasheet (& don't tell me that I now think I know better than Texas Instruments - just look at the plots)
Old 21st June 2010, 10:08 AM   #26
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Nothing to do with 'what I want' here - why make it into something personal? Cleaning a clock supply will also have the effect of reducing the RF content on the supply don't you think? Tell us more about how you cleaned the supply and what the cleaned supply was connected to on the board - I guess a clock osc but anything else besides that?
Its because of what I said earlier - perhaps you did not read carefully, So I'll say again - because in my experience sibilance is not caused by jitter, its caused by RF intermodulation. Reductions in reflections result in lower jitter you think? Any measurements to demonstrate that?
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 21st June 2010, 10:42 AM   #27
Banned
That's just a turn of phrase nothing else!
It went from a regulator to a battery supply but I'm not going to argue with you on this - you have your opinion that's fine!
First, I'm sure you understand that reflections arriving at the receiver during the decision window will superimpose a voltage onto the transition signal which will cause the decision point to shift to where it should be. Is this jitter? As to measurements - look at the TDR plots on DiyHiFi.org - it's plain as day!
Old 21st June 2010, 10:48 AM   #28
abraxalito's Avatar
So you cite avoidance of a non-existent argument as an excuse to avoid answering my question? Put your analyst on danger money baby
Ah but not 'plain as day' to me as I haven't been invited to join diyhifi even though I've applied. Without membership the attachments are invisible - one practical outworking of Jocko's paranoia.
Old 21st June 2010, 10:54 AM   #29
Banned
So you don't disagree about how reflections cause jitter, then! If that's the case then reducing them should be a good thing, no?
Old 21st June 2010, 11:00 AM   #30
abraxalito's Avatar
I'm not sure how you got that from what I said. I'm open to being convinced but as I've seen no evidence I'll remain sceptical.
Reducing reflections in isolation I'd say would be good. However, padding the line does not do that, as Jan has already pointed out. So I remain somewhat sceptical.
Closed Thread
generate jitter test signal and measurign jitter using AP2? BJAMR Digital Source 11 1st November 2010 02:07 PM
Attenuators stven Parts 0 12th January 2009 03:05 AM
Attenuators ------ Please Help soundbadger Tubes / Valves 5 13th February 2008 04:19 PM
Data Jitter Versus Electrical Jitter? 300_baud Digital Source 8 16th July 2004 07:59 PM
About Attenuators leiade Solid State 8 3rd November 2002 08:54 PM
Page generated in 0.13731 seconds (80.10% PHP - 19.90% MySQL) with 12 queries
