| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Sony's KSS-213 series are the most used optical pickup for compact disc players.
What are the differences between this laser heads (optical oick up): KSS-213A, KSS-213B, KSS-213C, KSS-213D, KSS-213E, KSS-213F, KSS-213V, KSS-213VS and KSS-213Q ?? About Mabuchi Motor datasheet and Application Note, Data Sheet, Circuit, PDF, Pinout | Datasheet Archive I have found datasheets about complete mechanism models datasheets about KSM-213CCM, KSM-213CDM and KSM-213CJM unfortunately all equipped with KSS-213C (last three PDF-files for download). So I cannot find here the differences to that one with other suffix. About Three Sixty HongKong Ltd Tel:008675588859995 Email:sales@threesixty.hk you will find pics from most of all (8 pages at whole). Thank you for your advices. Last edited by tiefbassuebertr; 17th June 2010 at 11:41 AM. |
#2 |
Hi
Just to bring up an old subject - can I replace KSS213QCS with KSS213CCM - they seem compatible but I'm not sure. The CD Player in subject is Xindak (pretty good one by any other standards). Thanks, Yair |
#3 | |
To find out appropriate models therefore, use one of the cross reference lists like CD-Spieler and perform reverse search. If you want to have KSM-213QCS datasheet, send me a PM to follow address: kirschner-hifi@tiefbasswiedergabe.de One different, that I know, is follow: the KSS-213Q is compatible to CDRW and the KSS-213C isn't. Last edited by tiefbassuebertr; 29th December 2010 at 01:28 PM. |
#4 |
Hi tiefbassuebertr
Thanks for that! I have replaced the crappy 213QCS with the 213CCM, works a treat! No doubt that the 213CCM is much better build quality. Cheers, Yair |
| Sony KSS213C | Ruach | Digital Source | 9 | 30th December 2010 10:32 AM |
| KSS213C LASER UNIT installation ? | fender62 | Digital Source | 31 | 1st November 2010 03:24 PM |
| is there a difference? | moray james | Everything Else | 91 | 11th November 2009 09:23 PM |
| difference between 1 and 2 | androtaker56 | Car Audio | 9 | 14th November 2005 12:36 PM |
| KSS213B Pickup | mattskinner | Digital Source | 0 | 17th October 2004 06:35 AM |
| Page generated in 0.08781 seconds (74.78% PHP - 25.22% MySQL) with 10 queries |
