Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
The Other Hawksford IV (nested loop op amps)
Old 6th December 2012, 05:35 AM   #11
jcx is offline jcx  United States
free manufacturer macromodels can be far from realistic
the output is usually a spice controlled ideal source - no output transistor properties are simmed
which is poor for simming pulse performance of older op amp built on semi prcesses with slow pnp - if you look with a scope at the real chip' output for mA steps you can see the pnp pull down "feedthru zero" recovery edge is bigger, recovery is slower
even with the modern better complementary isolated Q processes the op amp models are often poor on output properties - more critical as Cload stability becomes an issue - I don't really trust the sims I've posted here due to the unrealistic output modeling
The Other Hawksford IV (nested loop op amps)Hide this!Advertise here!
Hawksford Discrete IV with a Twist EUVL Digital Source 13 17th June 2010 08:42 AM
IV-convertor with op amps.... PA0SU Digital Line Level 33 6th April 2009 09:43 PM
Op-amp open loop bandwidth. beppe61 Solid State 18 18th February 2005 02:30 PM
Op-amps in IV, filter and buffer stages of a DAC Dr.H Digital Source 1 2nd June 2004 03:20 PM
