GUIDANCE NEEDED to mod - MARANTZ SA 7001 - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th June 2010, 07:04 PM   #11
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
Hi Sid, I use a DIY pre amp which is a tweaked Pedja Rogic discrete class A buffer stage running on DIY discrete low-noise regulators. My power amp is a modified 280wpc monster PA amp by Yamaha which runs class A up to 30W. The speakers are Jamo Concert 8's with improved crossovers and the tweeters are changed to Mundorf AMT (these are still a work in progress).
Ray, do you have any thoughts on the state of my output stage filtering? It seems as though the bass is excessive.
Cheers, Lee.
Old 8th June 2010, 07:56 PM   #12
6h5c is offline 6h5c  Netherlands
6h5c's Avatar
Originally Posted by trehansid View Post
Ray,
Whenever you are free, please let me hear from you in detail on possibly a few (about 3) options on clock w.r.t. price & source please. Also how to go about power supply for the same?
And any mods, that i need to do before the clock's introduction.
Many thanks & appreciate your attention.
Wishes
The Tentlabs XO and shuntregulator prices can be found at Tentlabs. The CD-clock and The Flea are DIY clocks, you'll have to build them yourself. There's more info on my website. The price strongly depends on the components you are going to use, so that's hard to say. But a fancy version of The Flea with it's own dedicated power supply and Tentlabs XO is about 65,- in parts.
The clock can be inserted anytime along the modification-ride, but be prepared for some serious SMD surgery (see pictures in my SA8400 section).
Ray
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 8th June 2010, 08:03 PM   #13
6h5c's Avatar
Dunno what causes you bass-problem, Lee. Sounds like that part of the HDAM section has trouble driving the output, maybe the output impedance is too high? This could lead to less control and bloated bass.
Ray
Old 8th June 2010, 10:33 PM   #14
arupg is offline arupg  Latvia
I go bang-on with the DOS as suggested earlier by Ray. Marantz & their HDAMs always create unpredictable new snags along the way.
Old 9th June 2010, 09:23 AM   #15
trehansid's Avatar
Ray
That was quick & generous
Thanks for your advice Ray.
Moving ahead with the electrolytics first.
Shall share details and then shall seek your guidance on what to buy next.
Appreciate your gesture to share with all the humility.
my wishes
:: QUAD 99,909 (modded with Blackgates+Nichigons+Aerovox) +B&W 805s +MARANTZ SA7001 +XLO ULTRA-6, Ref2 power cables +VDH D102 mkiii i/c
:: MARANTZ PM-15S1, CD6002 +DENON 2309 +QUAD 11L2+Center +WHARFEDALE DFS +PANA200U,BD30 +Supercube-ii
Old 9th June 2010, 10:58 AM   #16
6h5c's Avatar
No problem, Sid! And yes, please do share your findings!
Ray
Old 4th January 2011, 01:21 PM   #17
Thomo's Avatar
Hello again.
I've been working on my SA7001KI again so I thought I'd post a list of the mods I've done so far.
Thomo's SA7001KI Mods List
Cheers, Lee.
Old 4th January 2011, 01:24 PM   #18
Thomo's Avatar
Ray, I hope you still read this thread because my last mod may interest you as it's not something you've done yet I think.
I supplied IC734, 735 with their own low-noise supply. These are the logic chips for the clock frequency selection. It's made a big improvement to all aspects of the sound, particularly in air and space around the top end. I can't recommend it enough.
It's dead easy to do, just remove FB01 and feed in the new supply there.
Cheers, Lee.
Old 4th January 2011, 02:34 PM   #19
6h5c's Avatar
Hi Lee,
Yes, i'm still reading it
Nice list, you've been quite busy this month . I thought about removing IC734 and IC735 all together, and feed the clock directly to the DAC. There's just the problem of frequency selection, so it won't be able to play RBCD's after that. So I just left it as it is. But it must be adding jitter to the incoming clock-signal .
There's just one ferrite bead separating the IC's from the rest indeed, not very impressive. I have to open my player anyway, to fit a new analog output stage, and I have a spare Tentlabs shunt here. I'll have a look at it, thanks for the tip!
Ray
Old 4th January 2011, 03:12 PM   #20
Hi Lee
Super PSU you've got there. I like the biggie caps from Mundorf/FTCaps - one of the best around! You should be getting a night-to-day change in the 7001. Aren't you?
Arup
DIY Vinyl Cutter, guidance needed :+) loonatron Analogue Source 89 23rd November 2007 03:30 PM
Marantz CD75mkII to mod or not to mod that is the question. El_Hefty Digital Source 6 31st August 2006 01:29 PM
Guidance needed: Cost of restoration vs DIY vs part out.... dshoaf Planars & Exotics 6 14th April 2006 02:08 AM
Guidance for my new 7.1-System needed (Center, backward-Speaker) Blitz Multi-Way 1 16th May 2005 06:32 PM
First project: guidance needed eitanwaks Multi-Way 10 5th February 2005 06:10 AM
Copyright 1999-2017 diyAudio
