Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th January 2013, 06:14 PM   #91
UV101 is offline UV101  England
UV101's Avatar
Originally Posted by 6h5c View Post
A separate tranny is the best solution indeed, this voltage should be treated as 'digital supply' regarding noise.
Still have to look into that display-brightness-thing by the way...
4.5v Transformer en route!!
Must admit, I'm stumped by the brightness!!!!!
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk
JA-88D Class A, Audio Aero Capitole MKII, Focal and Kimber "Leave Nothing as Standard"
Old 8th January 2013, 07:14 PM   #92
6h5c is offline 6h5c  Netherlands
One Seriously Addicted to Audio and Electronics
6h5c's Avatar
You upped the heater voltage a bit, or was the player's voltage simply too low?
Gonna buy my little girl a pink soldering-iron
The new DOS-CFP board is out!
Old 8th January 2013, 07:19 PM   #93
UV101's Avatar
I changed the zenor voltage up but it made no difference!! Display is still too dim
Do you think lifting h1 and h2 might make it brighter Ray??! maybe 6v instead of 4.3v?
Old 9th January 2013, 06:09 AM   #94
6h5c's Avatar
Oh, I thought you meant that you fixed it with the new heater winding... never mind
Increasing the heater voltage may help, but the life span of the display will be shorter if it 'burns' hotter. I don't know what the nominal heater voltage is supposed to be for this display, so there's no way of telling what is correct.
Ray
Old 7th April 2013, 01:03 PM   #95
UV101's Avatar
I think Lee may have a fix for the dim display.......
Most definitely in the analogue engineering domain!!!!
Old 7th April 2013, 03:36 PM   #96
6h5c's Avatar
Always curious to see a fix for that. I haven't looked into it yet, it's still on my to-do list
Ray
Old 8th April 2013, 08:58 AM   #97
Thomo is offline Thomo  United Kingdom
Thomo's Avatar
It took a new window, the relocation of the IR sensor and a bit of work but the results are worth it.
The original window is so dark it's crazy.
Edit: I suppose I'd best say thanks to Brent for the new window.
Old 8th April 2013, 05:49 PM   #98
6h5c's Avatar
Nice
So a non-electrical fix, that's a good one
Is this an original replacement window that is clear? I'd love to have one for my SA8400!
Ray
Old 9th April 2013, 08:34 AM   #99
Thomo's Avatar
Hi Ray,
The replacement window isn't quite clear, it's just not almost black like the original!
I had to cut the new one down to size and file the edges to make it fit, but it was definitely worth it.
Lee.
Old 9th April 2013, 05:47 PM   #100
6h5c's Avatar
Very neat job. The original one is very dark indeed, during the day it's very hard to see anything on the display. Very annoying...
I WILL get this fixed, whether it will be electrical or mechanical!
Ray
DIY Vinyl Cutter, guidance needed :+) loonatron Analogue Source 89 23rd November 2007 03:30 PM
Marantz CD75mkII to mod or not to mod that is the question. El_Hefty Digital Source 6 31st August 2006 01:29 PM
Guidance needed: Cost of restoration vs DIY vs part out.... dshoaf Planars & Exotics 6 14th April 2006 02:08 AM
Guidance for my new 7.1-System needed (Center, backward-Speaker) Blitz Multi-Way 1 16th May 2005 06:32 PM
First project: guidance needed eitanwaks Multi-Way 10 5th February 2005 06:10 AM
Copyright ©1999-2013 diyAudio
