| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have an e-mu 0404 usb that I've been powering with a small variable linear power supply I have, today I had the power supply at 7.5v for something else and I forgot to switch it back to the 6v setting , the e-mu turned on an then turned off really quickly, now it doesn't turn on at all. I opened I up to see it just needed a fuse replaced but it doesnt use a fuse, Im wondering if the on/off switch acts like a circuit breaker and I just need to replace that? I contacted e-mu but they wont get back to me until Monday. I can take internal pics if needed
I have experience working on house wiring, I know how to use a multimeter and I can solder. |
#2 |
Electronic circuits have internal fuses that look like SMD resistors. If you don't have experience in electronics it will be very hard to fix it. And even then it might be impossible or too expensive - depending of the damage extent.
If you can point the camera on MACRO setting towards the power input, you might get some suggestions. |
#3 |
#4 |
In the first pic, the part marked with F1 is a fuse. Measured resistance across should be zero ohms.
#5 |
Yes it is 0 ohms
#6 |
I am probably digging at a topic that has been long inactive but i am hoping for somebody to answer!
I have the same problem with my 0404 just like SilverStrings... And it happened exactly the same way. So, the question is... Is it probably the fuse in the first picture to be replaced? Will this make my E-MU come back to life? And if yes, where can i find one? Thanks in advance guyz! |
#7 | |
If it is OK then connect the thing up and make sure you have the incoming supply voltage across the diode D8 next to the fuse. The outcome of that test depends on whether the problem is in the PSU or the unit itself.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#8 |
Thanks for the quick reply! Really appreciate it.
Unfortunately the fuse is not where it is supposed to be... A friend of mine took it off the board in search of a replacement, assuming that this was the problem because it was overheating (a lot!). But the real problem is that he could not find an equivalent to replace it. Do you have any clue where i can find a new one? Or could i put another fuse? And a board wiring diagram or schematic for the 0404 is nowhere to be found... I am all ears (or should i say eyes) for you to post a solution! Thanks |
#9 |
I would use a wire instead. The smallest one you can find (diameter), like one from a rf coil or litz wire.
Before measure resistance PAST that fuse - with a digital meter, the red probe to the fuse solder place (D8 side) and the black to ground. Should read more than a 10 ohms. D8 is a protection diode, that might be bad (shorted) too... |
#10 | |
You could do as SoNic_real_one suggests and link it out with wire to test. If you did try that I would just remove D8 to be sure. You must be aware of the risk (to the supply or USB supply/PC etc feeding the board) as if there is another fault it could possibly damage the equipment. Depending on your experience the best solution may be to link the fuse out, remove the diode and power up using either a current limited supply or 6 volt battery and check how much current is being drawn and whether the device works OK.
| E-MU 0404 USB Modification? | lumanauw | Digital Line Level | 67 | 7th February 2011 08:50 AM |
| EMU 0404 Sound Card | tripathdude | Digital Source | 5 | 23rd May 2008 04:46 PM |
| FS: E-mu 0404 USB external sound card | Jack Hidley | Swap Meet | 2 | 14th March 2008 01:00 AM |
| Modding my EMU 0404: Can someone please verify | bg4533 | Digital Source | 4 | 11th November 2004 09:32 PM |
| Page generated in 0.10872 seconds (79.45% PHP - 20.55% MySQL) with 11 queries |
