Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Ultimate USB to I2S interface
Old 18th June 2010, 07:43 PM   #111
chertk is offline chertk  Russian Federation
on this page there are links to digikey site with prices
https://www.xmos.com/store
Old 19th June 2010, 04:54 AM   #112
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by EUVL View Post
If the chip/driver bundle is affordable, the rest is easy, and we can make a restart.
The eval board costs 149 Bucks. XMOS says this about the driver:
"USB Audio Class 2.0 is natively supported by Apple OS X version 10.6.3 and above. Support for Windows is provided via XMOS partners, Thesycon and Centrance. The drivers are configurable and provide support for WDM/Direct X and ASIO 2.1."
"The Thesycon Windows driver is available through XMOS as a separate part number which bundles the driver with the XS1-L devices, not requiring any upfront NRE fees, or through Thesycon directly using a customer negotiated payment model. The Centrance Windows driver may be accessed via Centrance directly through a customer negotiated payment model."
"A Thesycon evaluation driver is supplied with the reference design."
The eval driver is not usable for a production system.
The XS-1 chips and most of their supporting capacitors etc. are not really suited to manual soldering, so I suspect that making your own is not really on the cards. This stuff definitly needs reflow soldering assembly for > 90% of parts.
I have worked with the XMOS Eval Board and Thesycon windows driver and at least the software side of the Eval Module and Eval drivers come are a bit ropey. Especially next to the extremely reliable and slick Musiland drivers. So you probably need to customise code and get a custom driver or customise Thesycon's one.
Ciao T
Old 19th June 2010, 06:39 AM   #113
EUVL is offline EUVL  Europe
Thorsten,
Have you use the XMOS with their Mac driver ?
Is that any better than the Thesycon ?
Thanks,
Patrick
Old 19th June 2010, 07:31 AM   #114
There is no Mac driver. USB Audio Class 2.0 support is build into the latest versions of Mac OSX, however it is rumored to be buggy and flaky. I don't really mess around with Mac's, so I would not know.
Ciao T
Old 7th August 2010, 05:22 AM   #115
barrows is offline barrows
Default still looking for...
a USB to I2S solution for installation in my DAC.
My 2 cents:
1. Asynchronous
2. Onboard, fixed oscillators, with on board mini shunt ps regulation (has to be near the clocks, not running through a bunch of wire to get there)
3. up to 24/192
4. No driver for Mac (or very reliable driver, but should not be necessary)
5. Can run off of the USB bus power with appropriate filtering on board (USB bus power does not seem to hurt the performance of the Ayre QB-9, either in measured jitter spectrum, or sound quality)-paranoids can always hack into the USB jack to provide a different supply, or provide pads with jumpers on the board for external supplies.
6. No SPDIF, no external clock input (good onboard XOs with good supplies negate any possible external clock advantage)
There is no real point in doing this as SPDIF out, as there are already very good commercial solutions for achieving this.
Personally, I would be willing to pay up to $200.00 for a properly implemented board (designed by someone who understands high speed/RF design) that I could stick in my DAC. It just does not seem likely that $50-$75 dollars is going to cover the development costs of such a project.
Old 7th August 2010, 05:49 AM   #116
regal is offline regal  United States
As I understand it the Ayre has galvanic isolation from the USB input, this is how they get clean I2S and a key to their good measurements, it's not possible to galvanically isolate 192khz USB.
Old 7th August 2010, 05:55 AM   #117
Default Well...
Not sure what they are doing now, but current versions of the QB-9 are now capable up to 24/192, and they are offering the new USB receiver as an upgrade for existing QB-9 owners. This has been made possible by Gordon Rankin's new Streamlength Async USB code and hardware choice.
Old 7th August 2010, 07:07 AM   #118
jcx is offline jcx  United States
isolation between the USB slave uC and the hardware deriving I2S for the DAC can be byte wide and handle 100s of Mbits/s with DMA/FIFO for the USB data
Old 7th August 2010, 07:52 AM   #119
if you could fill in us audio guys it would be appreciated, we've all been sear hing for a means to galvanivally isolate our M2Tech Hiface boards.
Part numbers, datasheets, etc.
thanks
Old 7th August 2010, 03:16 PM   #120
Default looks like...
a good opportunity here for someone to make this (or a diy manufacturer). I bet their would be a lot of buyers for a board like this, every kit and diy DAC could use one, and competant folks would be installing them in OE DACs as well.
Clearly it can be done...
Ultimate USB to I2S interfaceHide this!Advertise here!
HDD to I2s interface elnec Digital Line Level 6 15th September 2008 09:43 PM
I2S interface to PCM63 robo Digital Source 7 6th March 2007 08:23 AM
Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input dkj7a Digital Source 1 26th March 2006 06:46 PM
I2S interface? pooge Digital Source 3 28th June 2004 06:10 PM
interface I2S with USB mermoz Digital Source 0 21st February 2003 11:34 AM
