| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I thought I'd do a brief guide on changing this as a couple of people have asked me about it when I mentioned it in another thread. It's very easy to do and the gear and belt are available on Ebay at the time of writing for about £12GBP. The player shown is a Marantz CD52, but the CD42 is the same and probably the CD32 too.
Step One: Remove the four side screws on the case lid (Philips-drive screws) Step Two: Remove the T10 Torx screw from rear of case lid Step Three: Remove lid Step Four: Fold back disc clamp flap Step Five: Remove spring from flap
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) Last edited by SimontY; 21st May 2010 at 10:53 AM. Reason: more detail |
#2 |
Step Six: Remove the 3 torx screws from the front panel
Step Seven: Unclip the front panel from the sides of the main chassis Step Eight: Remove the torx screw from the underside of the chassis at the headphone socket end Step Nine: With the player resting on its back, pull the face-plate slightly forward and carefully withdraw the tray. It doesn't need to be forced. Step Ten: Return the player to its normal upright position Step Eleven: Remove the old belt and tray/draw cog
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#3 |
Step Twelve: Check the part against the new one and insert the new cog after placing the belt around it and the motor pulley
Step Thirteen: Clean the lens with pure alcohol and a cotton swab whilst you're in there (if you've never done this before) Step Fourteen: Reinsert tray, clip the front panel back on and put the lid and all screws back as you found them. Done! I hope this is useful. Simon
#4 |
thanks Man!! I just fixed my cd52. I took the gear from a magnavox CD610. I will replace that one later.
#5 |
Thanks! Owner of a CD 52, waiting for the replacement parts to arrive. Your guide will be very useful!
#6 |
Brilliant guide - CD52 now back working correctly - Thanks
#7 |
Just replaced the cog and belt on my (20-ish year old) CD42 with parts bought off eBay for under 8 quid. Never done this type of repair before; the guide was really helpful - did it in under half an hour. Thank you!
#8 |
One question. What is the dimension of the belt?
Regards, f. |
| Marrantz Cd42/52 Draw Gear | bull041161 | Digital Source | 8 | 14th January 2010 05:30 PM |
| Wtb Cdm4/19 | Mikelo | Swap Meet | 0 | 24th January 2005 12:49 AM |
| Cdm4/19 | halewood | Parts | 1 | 26th October 2004 05:08 AM |
| Repairing CDM4/19 (with CDM4/31???) | Shaun | Digital Source | 4 | 1st August 2003 12:29 PM |
| Where to get CDM4/19 laser? | Shaun | Parts | 2 | 28th May 2003 05:19 AM |
| Page generated in 0.16074 seconds (49.34% PHP - 50.66% MySQL) with 11 queries |
