Replacing the draw cog and belt on CDM4/19 e.g. CD42/CD52 - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th September 2013, 12:45 PM   #21
Johno is offline Johno  Australia
Johno's Avatar
The Valab TCXO arrived today for the CD52. Took its time I must say.
Still crunching numbers to optimise the 5v regs but have settled on making 3 using REG103's - one each for the analogue and digital supplies for the DAC and one for the Clock. I expect this to take the load off the remaining 5V digital stuff as well as reducing the overall current in the original transformer. I am beginning to think that anything else is past the point of diminishing returns.
But I am really enjoying the SQ improvement just from re-capping.....
Old 19th September 2013, 09:06 AM   #22
Johno's Avatar
Default CD52 mods
Finished the mods. Result is amazing and making my speakers (which are Manzanitas by the way) really sing. Finally piano sounds like piano and the Stones sounds like I am there. And its so clear, it really does sound live, well the good recordings anyway.
I'll have a figjam syndrome now for sure.
Summary of changes
New drawer cog and belt
Recapped the existing power supply with the biggest Panasonic, Nichicon or Rubycon caps I could find AND that would fit - essentially very tall, same diameter - about 25 of them all up.
Removed the capacitors across the rectifier diodes
Added snubbers across the transformer secondaries (780R + 100n)
(Now the unit is very quiet)
Added a second transformer 20VA 9+9 torroidal (careful to preserve the double insulation)
moved existing fuses to the primary side - the second fuse is now for the new transformer
snubbers across the secondaries (390R + 100n)
4 bridge rectifiers + largest smoothing caps that would fit (4700/35)
6 x uA78L05 regulators, 4 for the DAC analog, one for DAC digital and one for the clock
TCXO from Vintage Audio Labs in Taiwan
The 4 analog regs shared one transformer winding and the digital regs the other winding. My thinking is that the new transformer leaves plenty of VA without droop for the servo circuits on the original plus isolating the DAC from the pervasive digital noise.
Seems to work.
John
Old 20th September 2013, 06:59 PM   #23
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Brilliant, and thanks for sharing your experiences of those upgrades. Very interesting.
Old 28th September 2013, 01:04 PM   #24
Default Thank you
I've just replaced the wheel/band on my Marantz CD52 MK2 Special addition using your instructions and it is now working perfectly.
I want to thank you very much indeed for your easy to follow instructions.
The only problems is that I have been left with a small spring about .5 of a cm long and .2 wide. It has flat ends with no hooks.
As everything seems to be working well I am content to leave well along unless the omission of the spring is desperate
Once again thank you so very much indeed.
Old 5th October 2013, 03:43 PM   #25
Default Fantastic
Thanks so much. Piece sourced from the Far East for 5 and 15 minutes of labour. When removing the screw near the headphone socket I had to take out a second screw in the middle to move the facia but other than that no problems. Might I be the first woman to achieve this??? lol. Sarah
Old 11th October 2014, 11:41 AM   #26
Thanks for your instructions. It was pretty easy to fix my Technics cd player SLPG200A.
Merci!
Thibault
Old 17th January 2015, 10:15 PM   #27
Tom72 is offline Tom72  United Kingdom
Many thanks, SimontY. You made it all very clear for an amateur. Tom from L23. UK
Old 22nd May 2015, 07:30 AM   #28
Resurrecting this thread again momentarily just to say thanks to Simon for a guide that made it easy.
Many thanks, and Cheers!
Marrantz Cd42/52 Draw Gear bull041161 Digital Source 8 14th January 2010 06:30 PM
Wtb Cdm4/19 Mikelo Swap Meet 0 24th January 2005 01:49 AM
Cdm4/19 halewood Parts 1 26th October 2004 06:08 AM
Repairing CDM4/19 (with CDM4/31???) Shaun Digital Source 4 1st August 2003 01:29 PM
Where to get CDM4/19 laser? Shaun Parts 2 28th May 2003 06:19 AM
Copyright 1999-2017 diyAudio
