Arcam Alpha mods - Page 53 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 8th January 2012, 01:08 PM   #521
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
I just solder to the copper ground plane sometimes, works fine. Sure, it's not necessarily ideal but I'm not clever enough to do perfect grounding so I won't let it worry me too much.
Old 8th January 2012, 02:19 PM   #522
Exactly the answer I was looking for - thanks.
How's it going at your end - have you found and fixed the problem ?
Old 8th January 2012, 02:21 PM   #523
SimontY's Avatar
Nope, I can't be bothered right now. I've just bought a new car so that's taking up most of my "hobby" attention. I just turn it on, listen to an album, then turn it off to cool down ready for the next one. I know that is very poor and I will do some proper fault-finding soon.
Old 26th January 2012, 10:12 PM   #524
Hi
I have just got my hands on an Alpha One? I'm quite impressed with it considering it's age, especially with the size of the soundstage. Do any of you Alpha mods apply to the alpha one?
My frst problem is with the drive which will read cds if I give the disc a little spin myself, to get it started. If not it struggles, gives up and says no disc. Once it's going there are no probs with the sound. Any idea how I ight fix this?
I'll put it through my DACMAGIC eventually so I imagine it's not worth replacing the DAC, is that right?
I was going to leave the opaps to begin with to see if I could work with the character of the current ones, however I'm always open to interesting suggestions!
Finaly if anyone had the service manual I'd be very grateful if you would share it with me.
Many thanks
Old 5th February 2012, 02:25 PM   #525
acccruz is offline acccruz  Portugal
Post SRPP I/V output stage
Hi:
After trying several op-amps in my moded Arcam Alpha 5, running in class A, I must agree with Mr. Fikus when he said: "there is no better op-amp like no op-amp"!
Again I must agree with lampizator when he said the tube I/V output alone represents more than all mods you can do in the CD player.
Here my mods:
All digital caps changed for Os-con SPEC;
All power caps changed for Rubycon ZL;
Changed the resistors board for PRP metal film and some Takman;
LM regulators changed for best Motorola;
Diodes changed for Motorola;
Added some inductors before the power resistor of the digital chips;
NetAudio Clock;
NOS;
DEM;
Op-amps (tryed several among the best) running in class A;
SRPP 6N2P-EV tube stage for I/V output (the best!)
Here some pics about my I/V srpp tube output stage.
It is not look nice but it sounds amazing!
Old 5th February 2012, 04:54 PM   #526
Default Some aditional notes
Future plans:
Make my salas shunt reg to feed the TDA1541A and SAA7310;
Feed all other chips with is own regulator (LM337T or LM317T);
Make two wood boxes like these ones for Arcam Alpha:
Sell my reference (until today, because the Arcam sound much more additive!) Electrocompaniet EMC1-UP player;
Read this: Electrocompaniet
Make my OWN opinion about the debate: which sounds better? vinil or cd?
ENJOY the music and pray for the sun! The winter are cold in Portugal.
Old 14th April 2012, 12:56 AM   #527
Default DEM mod
Hi Andrew:
I have done your sugested DEM mod but I have a lot of noise in the sound!
Will you help me to solve the problem please?
Thank you,
Antonio
Originally Posted by AndrewGM View Post
Final implementation as attached.
Just running unit now - too early to say.
Works great though - more later
Old 14th April 2012, 02:34 AM   #528
Tell me what you have done and I'll do my best to help.
I made some mistakes too - don't mind admitting it.
Andrew
Old 14th April 2012, 11:54 AM   #529
Default DEM mod
Hi again Andrew:
I follow your schematic.
I forget to say I have the player running in NOS mode - may it will be the noise cause...
Soon I will post some pics.
Many thanks for you quick reply,
Antonio
Old 14th April 2012, 12:39 PM   #530
It might be NOS thats a problem - but the real problem is I don't know these things technically enough to make a statement - sorry.
In the end I took it ( DEM mod ) off because I too had some noise problems with it and instead I concentrated more on the power supplies which gave me really significant gains.
A little bit like SimonT's work but without so much reserve VA
Do you like the NOS sound ?
I recently did it on an Alpha 5 and removed the SAA7220 completely. There are certainly gains in sound quality in the bottom end and midrange but I'm still not sure about the hf roll off. I'm sure I can hear it.
It's never going to be a match for my old Alpha even without DEM mod.
Arcam Alpha 5 cd schematics and mods wanted Chivvyp Digital Source 5 21st March 2010 11:36 AM
Arcam Alpha Plus amc184 Digital Source 6 17th January 2008 07:01 PM
arcam alpha 7 big jim Solid State 3 19th June 2006 12:40 PM
Arcam alpha 9 pumpkin Solid State 0 5th October 2005 07:31 PM
Arcam Alpha 8 ManUtd Digital Source 4 5th April 2004 03:23 PM
Copyright 1999-2017 diyAudio
