| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#511 |
Could you describe more specifically what it does when it cuts out? Does it just stop playing, does it lose the ToC info or does it shut off completely?
Inside Classic Audio, my blog on repairs, modifications and anything else to do with audio. |
#512 |
Excuse a slightly off topic moment. I too have sidelined my Alpha for a bit. Recall in my case I messed up the main board and the balance ended up as a USB/1541a/tube dac. The PCM2706 USB died. No, that's good news as I wanted to upgrade to asyncronous USB. Have ordered an XMOS based board from a cool guy on this site. The interesting thing is it will enable me to play high res content on the Arcam audio board. 24/192 will be possible. I know the 1541a is only 16 bit, but it will apparently ignores the extra bits and sounds great. Should be interesting to hear.
This has spawned a couple of projects. USB2 is best supported in Unix, so I am dabbling in those waters toying with a dedicated Alix processor that picks music off a netserver and passes it to the USB. Easy to build power supply and may even fit in the arcam box. Very cool, but complicated. ![]() Meanwhile, I messed with my backup CD to the point of destroying it. So last night went looking for a new Alpha and tripped over a Rotel 855 for sale in my home town. Its the real deal, German engineered, 1541A N2 chip & Blackgate caps for $100! With just a power cord swap to take conditioned power, its rivalling my earlier efforts. I plan to take our best learnings from this site and like Andrew take my time this time. Who knows where that will end up. I must say I am addicted to the 1541a![]() I am enjoying a quiet new years eve at home with my wife, fine food, German beer and fine music. All the best for a happy and safe new year. |
#513 | |
Happy New Year everyone
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#514 |
That's exactly what mine was doing. I'd have at look at what the mainboard's +5V rail is doing once the player has warmed up. I'd also check on the temperature of the mainboard's 7805 regulator and make sure it's still well mounted to its heatsink. If it's a 78M05 type (the medium power version) I'd replace it with a 7805.
If that doesn't turn up anything of interest, maybe it's time to get a can of freezer spray and see if cooling anything has any effect.
#515 |
Fantastic, cheers.
And Walter - that project sounds amazing. It does sound rather complex too! The Rotel sounds fun too.
#516 | |
Don't want to be a doomsayer I had a similar problem once, turned out to be the 1541. It was easy for me to check as I had a spare chip and it was on a socket. Once the new chip was in I never had the problem again.Regards Pete |
#517 |
Hi Pete,
Could that be random chance? I didn't think the 1541 chip actually affected playback in these machines - just whether you can hear it or not. Simon
#518 |
yeah, I missunderstood your symptoms, thought you were just losing sound
#519 |
Nope, it just stops with an "error" after a 35-40min warm-up period of perfect playback. I've got an annoying cold or something so feeling lazy about fixing this!
#520 |
New topic :
On the Phillips main board I, like everyone else who have them, have several factory made solder blobs on link wires that act as grounds - which are pretty handy. Being that they are all effectively soldered ( connected ) to the copper cladding on the surface can I just create my own anywhere I please ? This is purely for my own convenience as I decide where to put my regs - in an effort to get them as close as possible to the receivers. Am I wrong in assuming I can just add solder to it and use that new point or must I connect to ground at the nearest available original solder blob ? Thanks |
| Arcam Alpha 5 cd schematics and mods wanted | Chivvyp | Digital Source | 5 | 21st March 2010 10:36 AM |
| Arcam Alpha Plus | amc184 | Digital Source | 6 | 17th January 2008 06:01 PM |
| arcam alpha 7 | big jim | Solid State | 3 | 19th June 2006 11:40 AM |
| Arcam alpha 9 | pumpkin | Solid State | 0 | 5th October 2005 06:31 PM |
| Arcam Alpha 8 | ManUtd | Digital Source | 4 | 5th April 2004 02:23 PM |
