Arcam Alpha mods - Page 21 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 15th July 2011, 03:56 PM   #201
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Any gains from the extra cap, Andrew?
Could we use a small film cap, say 470nF or 2.2uF? Is low impedance a key factor?
Old 15th July 2011, 04:05 PM   #202
A film cap could work well, but remember you are tying the output of two active regulators together with it - so really high Q /low-ESR isn't good and will promote ringing on either or both supplies (hence my note on damping). Small film cap with a series reisstor could be worth a try, say 1ohm. But a small oscon seems to work OK generally, esp if you have largish caps on the 1541 pins already (eg 47uF).
Definitely something to play with that works better if you can drive a 'scope!
Old 15th July 2011, 06:58 PM   #203
Actually I think there is - seems more lively but my mind is on this .....g D flip flop thing I've got myself embroiled in - sorry.
I'll be firing it ( DEM ) up again soon then I'll report back on both things with something a bit more coherent
btw...It's on the alpha 5 - tonight it'll be on the alpha because.... it works and is stable.
Have you got any 10 uf oscons spare ?
You can have one if not
Andrew
Old 15th July 2011, 10:59 PM   #204
SimontY's Avatar
I've not and thanks but I'll just find something else like a film + damping resistor.
So it works on one player, good luck implementing it on the main one
Simon
Old 15th July 2011, 11:52 PM   #205
Yes - it may be exquisitely temperamental to impementation if you dont have a scope, but if it works, you can look at better answers [ eg floating a 10.0v reg between these pins - that's a gross hint, which definitely needs a 'scope ]
Old 16th July 2011, 12:06 AM   #206
Yes Simon - it's a winner - go ahead
It's another step - not huge but there's more to the edges of percussion and it feels like the attack speed is just more lively - as I reported on the ' 5 '.
I wish I could describe this stuff better - apologies.
I also wish I understood better why these little tweaks work.
Yes I can read the explanations by you and Martin and others too but it's just grasping it that ' does me in '
DEM method is aborted and I'm implementing this instead ( attachment )
Flip flop's are now officially for holidays not CD Players.
Anyway, once I get this running I'll post pics
Martin - thank you - it's a nice one
Andrew
Old 16th July 2011, 12:10 AM   #207
Walter - you too - give this a go - it's good un..
Andrew
Old 16th July 2011, 03:21 PM   #208
wlowes is offline wlowes  Canada
wlowes's Avatar
Andrew
Ok - now for a head scratcher... does C227 not already do this?
-5 @ pin 26 goes to digital ground via c221,c222
-15 @pin 15 goes to analogue ground via c224,c225
digi and ana ground are tied together via c227. Basically we are adding caps to c227
I think I actually killed that one some time ago thinking it would be good to have digital ground not send very high frequency over to analogue ground. I thought at the time it was good. I have a couple of options in my used cap drawer. There is a BGN 47U at one extreme. At the other end are my newly aquired 1500pf silver mica russian military looking for a use. perhaps its time to experiment. Thoughts?
Old 16th July 2011, 03:53 PM   #209
Had a look at the schematic now - no, this extra cap i suggest is doing something quite different.
C227 is odd to me - most other implementations (and the quietest way of doing things) would be to have just one ground plane and the analogue and digital grounds going into it. The only reason these have different pins on dacs is to keep the current loops inside the chip separate - sharing one tiny internal bond wire for all digital and analogue 0v return current would badly degrade performance by crosstalk.
Old 16th July 2011, 04:43 PM   #210
Martin - are you saying get rid of the cap 227 altogether and put a wire link across connecting both D & A grounds together ?
Arcam Alpha 5 cd schematics and mods wanted Chivvyp Digital Source 5 21st March 2010 11:36 AM
Arcam Alpha Plus amc184 Digital Source 6 17th January 2008 07:01 PM
arcam alpha 7 big jim Solid State 3 19th June 2006 12:40 PM
Arcam alpha 9 pumpkin Solid State 0 5th October 2005 07:31 PM
Arcam Alpha 8 ManUtd Digital Source 4 5th April 2004 03:23 PM
Copyright 1999-2017 diyAudio
