Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Arcam Alpha mods
Arcam Alpha mods
Old 5th July 2011, 09:25 PM   #141
AndrewGM is offline AndrewGM  United Kingdom
Hi Simon
Did you read this statement below by ecdesigns in the ' building the ulitmate NOS dac using TDA 1541A ' ?
OK, we're not NOS people but it's quite an eye opener anyway :
Originally Posted by -ecdesigns-
Tuning the capacitor is the easiest way for lowering DEM clock jitter amplitude, but jitter won't be as low as with an low jitter external DEM clock (DEM clock oscillator intrinsic jitter). So this modification improves sound quality over the 470 or 680pF, but still isn't optimal - unquote
So, another simple mod without doing DEM exists by getting a better lock to BCK using one of 9 values of cap outlined in the thread.
I'll be ordering the caps tomorrow - I'll let you know what happens if your interested.
I'm also itching to try the DEM mod .....but I want you to do it first....
Hope all is well
Andrew
Old 5th July 2011, 09:29 PM   #142
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Hi Andrew,
I recall reading about the optimal caps but thought it would be so hard to hear the difference I just left it alone... for now. I'm very interested in what you discover. I'll do the DEM re-clock at some point.
Simon
Old 5th July 2011, 09:31 PM   #143
some more...
so instead of building the differential 352khz DEM clock (derived from masterclock) is it worth to try with only one 250 pF quality cap that will lock on 352.8 khz on DEM pins (16,17) ?
Answer was ' yes ' but not as good as proper DEM job - I'll bet you've read this already ?
Andrew
Old 5th July 2011, 09:33 PM   #144
SimontY's Avatar
That's cool to know. Is that a readily available value or is it made up of 220pF + 22pF + 8pF or something mad like that??
Old 5th July 2011, 10:00 PM   #145
No, actually straight 250pf exists in silver mica and styrene.
Though the guy insists low tolerance of 1% ......what ?
I've found mica's at 2% and I've asked him the question already - is it oK to use.
If I have to buy a bag full I'll send you some foc !!
Cheers
Andrew
Old 5th July 2011, 10:15 PM   #146
SimontY's Avatar
Thanks Andrew! Clearly the value is ultra-critical.
Old 7th July 2011, 12:11 AM   #147
OK, I've got three 2% mica's coming - apparently that's fine.
Considering my styrene's were 10 % means 2% is a bit of a result !
I need two - the other one's yours.
Only one issue - the pitch is about 12 mm !
I'll give it a go anyway.
If you PM me your address I'll send it as soon as they arrive.
Andrew
Old 7th July 2011, 09:08 AM   #148
SimontY's Avatar
Thanks Andrew, a PM has been sent your way.
12mm is very wide (typical silvered mica) but they usually come with long leads IIRC so it should be ok to fit.
Old 9th July 2011, 10:59 PM   #149
They're here !
It's in the Alpha 5 now but it's too early for me to comment as I'm half way through a bottle of red - plus the 5 is completely different sounding to the Alpha
My poor Alpha 5 gets everything thrown at it first to see if it explodes and if it doesn't after a few hours I apply it to THE ' reference '
Hopefully tomorrow I can get it in and report back.
No probs though and no ' nasties '....meaning it's not worse for sure !
Yours will be with you Tuesday
Cheers
Old 10th July 2011, 08:43 PM   #150
SimontY's Avatar
That's great Andrew! Any further comments on the sonics? Is a new cap in the reference machine yet?
Arcam Alpha modsHide this!Advertise here!
Arcam Alpha 5 cd schematics and mods wanted Chivvyp Digital Source 5 21st March 2010 10:36 AM
Arcam Alpha Plus amc184 Digital Source 6 17th January 2008 06:01 PM
arcam alpha 7 big jim Solid State 3 19th June 2006 11:40 AM
Arcam alpha 9 pumpkin Solid State 0 5th October 2005 06:31 PM
Arcam Alpha 8 ManUtd Digital Source 4 5th April 2004 02:23 PM
