Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 9th May 2010, 12:10 AM   #1
dtm1962 is offline dtm1962  Canada
Default Advice & Questions:On upgrading Power Supplies for a Rotel RCD-855
I have a Rotel RCD-855 that I have begun modifying to improve sound quality.
I have replaced all the electrolytic caps on the board, made it NOS and I want to begin upgrading the power supplies especially the+5VDC digital.
I want to have a separate supplies for the SAA7210 (+5VDC), SAA7220 (+5VDC), TDA1541A (+/-5VDC) and as well the analog output stages (+/-15VDC). The existing 7805 will handle the TDA8088/9 & microProcess and other miscellaneous chips.
Questions:
1) Should I use a separate dual secondary/CT transformer for these power supplies or should I tap off the existing xformer that has ~14VAC CT & ~25VAC CT (common CT among both supplies?!?!?)
2) If I do use the existing secondaries is there a problem with sharing a common CT for each of these secondaries?
3) Do I convert (to the new dedicated +5VDC) ALL the +5V feeds including some indirect feeds (ie say +5V feeding a transistor/diode/resistor that feeds another pin on the say.. SAA7210 or JUST the VDD (+5VDC) of each 7210/7220/1541 (-5VDC on 1541 as well)
4) Is there any concerns with say my new +5VDC being slightly different (in regards to say +4.9VDC versus the existing 7805's being 4.7VDC in regards to the proper operation of the circuits. Is there any potential foor upseting the proper operation
5) Do I just lift/desolder the upside (line side) of the resistor/inductor and solder my new PS feeds to this lead which is in series with the +5VDC pin (Pin 28 on 1541A; Pin 24 on the 7220P/B & Pin 40 on the 7210). I'm assuming this is better than cutting the tracing as there are other +5VDC feeds downstreams of these chips and I have to be careful not to cut off its +5V.
Any advise would be helpful on this.
I will be adding a new 11.2896 clock as well as feeing the clock direct to the 710 & 1541 (11.XX Mhz & /2 clocks for 1541) versus being fed from the 7220.
Thanks in advance,
Dan
Old 9th May 2010, 06:06 AM   #2
Default Furter Note...
I forgot to mention.... these specific power supplies for the 7210/7220/1541 to be built on separate boards using 317/337 regulators with 2200uF feeding 317/337 with 1000uF on the outputs.
I will have a +/-5VDC for the 1541; +5VDC for the 7210; a separate +5VDC for the 7220 & +/-15VDC for the outputs so I will have 4 small power supply boards mounted in the huge space available in the metal cased enlosure. I will also mount a new digital clock board adjacent to the 7220. I will probably bypass the 7220 & feed the clock signal directly to the 7210, 7220 & 1541 versus letting the 7210 feed the other 2 chips. I am referring to procedure as described by ECDesigns titled "Advanced re-clocking for TDA1541-based cd players"
Dan
Rotel RCD-855 stopped working Mr DNA Digital Source 5 26th November 2009 07:26 PM
pioneer pd-206 & rotel rcd-855 cd players georgepogi69 Digital Source 1 1st September 2009 08:13 PM
Rotel RCD 855 Schematic P Howard Digital Source 0 18th May 2004 08:40 PM
Rotel RCD 855 tonitze Digital Source 16 30th June 2003 02:58 PM
Rotel RCD-855 users ashok Digital Source 1 5th August 2002 05:53 PM
Page generated in 0.06383 seconds (82.73% PHP - 17.27% MySQL) with 10 queries
