Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 20th June 2003, 06:35 PM   #11
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Default The standards listings:
From the ATSC website:
http://www.atsc.org/standards/a_52a.pdf
Not a bad read at 140 pages, shouldnt be too tough to produce as C++ (but dont waight for me to do it)
The Errata Listings from the Dolby web site:
http://www.dolby.com/tech/ATSC_err.pdf
Note: errata seem to predate the ATSC listing and are therefore likely to be included in the document.
Old 20th June 2003, 06:59 PM   #12
Originally posted by Schaef
Uhm, unless you know the source, DTS is NOT freely available.
http://webapp.etsi.org/action%5CPU/2...14v010201p.pdf
Old 20th June 2003, 07:11 PM   #13
Da5id4Vz's Avatar
Default Publish or perish,
We'll try to post some of our research here (censored of course).
Pierre Watts
The bane of academics, and great resume material too.
Perhaps more importantly, depending on where you go with it, this sounds like it could also make a good AES journal article.
Old 23rd June 2003, 02:20 PM   #14
Schaef is offline Schaef  United States
Very cool, thank you! Now, to find time to read it!
Old 23rd June 2003, 05:11 PM   #15
You should be aware it is not quite complete.
ray.
Old 23rd June 2003, 05:17 PM   #16
A 8 is offline A 8  Sweden
While it is possible to get 6 individual compressed AC3/DTS datastreams, I have not seen any chips that put out 6 decompressed datastreams.
Not sure what you want to say with this but I would say all decoders do that...(unless you refer to spdif) that's what their job is. OK, you don't get 6 individual streams you get 3 pairs of decompressed datastreams, the lr clock to identify each one and the bit clock needed. Just as the signals that feeds any other PCM DAC chip.
If you want single streams as in a DIT you can add the AKM4101
8 ch DIT
I think it would be easier to get a commercial product and re-build it, besides getting usable digital audio data you also get timing adjustments and the dd or dts sonic "stamps" right.
I've managed to extract DD and DTS decompressed pcm data from the Motorola DSP56362 and Analog devices Melody 32bit processor.
The zoran would give you the same thing.
BTW I think zoran is used in Toshiba dvd players. Pioneer uses motorola and Denon uses analog devices melody.
I think you can get a new player that includes these for around $500.
Old 25th June 2003, 06:01 PM   #17
Da5id4Vz's Avatar
Default Sound Blaster Extigy
I stumbled across this today while I was avoiding work:
The sound blaster Extigy claims to have a stand alone function where it will decode DTS w/ out setup from a computer.
http://www.soundblaster.com/products...asp#easeofuse2
Old 25th June 2003, 07:21 PM   #18
tiroth is offline tiroth  United States
AFAIK the extigy only does DD. If it can do DTS, let me know, because I have one at home. I use it mostly for digital I/O.
Old 25th June 2003, 07:26 PM   #19
Da5id4Vz's Avatar
OOPS!
Those achronym things always mess me up.
Hope no one ran out and bought one becasue I said it was so.
DIY 5.1 decoder pixie Digital Source 47 14th November 2011 05:32 PM
5.1 decoder soundNERD Digital Source 82 22nd September 2011 07:52 PM
AC3 decoder IC? ROBSCIX Digital Source 8 6th March 2007 06:34 AM
DTS decoder on PC george a Everything Else 5 10th May 2006 01:17 PM
MP3 decoder Diogo Parts 0 23rd August 2002 03:18 PM
Page generated in 0.10248 seconds (77.06% PHP - 22.94% MySQL) with 11 queries
