Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Do these Philips' CDM4 fit with my NAIM CDI?
Old 28th April 2010, 07:40 PM   #1
marcot is offline marcot  Italy
Smile Do these Philips' CDM4 fit with my NAIM CDI?
Hi everyone:
I've just found the following Philips
1. CDM4/53 9107 AH E- with an aluminum body and a Hall motor.
2. CDM4/52 9420 AH E- with a plastic body and a DC motor.
Since I have a NAIM CDI with a CDM4/22 or 27, do you know if I can replace it (the mech or the pickup only) with the mechs above?
Any idea or suggestion?
Many thanks
Marco
Old 28th April 2010, 08:59 PM   #2
jotom750 is offline jotom750  United Kingdom
Hi.
See This thread:-
Naim CDI Transport replacement?
I have put a CDM4/19 laser arm onto a CDM2/10 mech, no problem at all, just had to also change over the pair of small cast mounting lugs.
There seems to be an amount of commonality between the swing arm mechs.
Old 29th April 2010, 04:00 PM   #3
Hi
and thanks for your answer.
Ok for the laser, but what about the motor and the body?????
Any experience?
Marco
Old 30th April 2010, 11:45 AM   #4
Hi Marco.
I think your best bet is to look at your mech and check up on the others used in Philips and Marantz machines. There are mostly 2 types of motor (Hall or Brushed) and 2 main types of support plate (Large CDM1 mk2, CDM2 and 4/11 etc and small CDM4/19). No dought there are others though.
All the best.
Old 5th May 2010, 05:38 AM   #5
Rajkumar_ is offline Rajkumar_  India
Arrow Meridian CD Transport 207
Hello Jotom750! Can you help me; I have planned to change my meridian CDM2 laser arm assembly with a CDM4 laser arm assembly. Note: Meridian 207 CDM2 Servo PCB I (which one has five connectors on PCB) Is it can swap arms without any electronics modification? I read some information in here:http://bakura.nl/2009/10/06/cdm2-revision/ Mr. Bakura saying needed some modification in electronics, there is a document! I do not know where do I found? You had experience; please give me your advice!
Thanks in advance for your support!
Raj
Do these Philips' CDM4 fit with my NAIM CDI?Hide this!Advertise here!
Help for a Naim CDI (CDM4/x)'s laser marcot Digital Source 34 15th February 2017 09:05 PM
Naim CDI Transport replacement? johnm Digital Source 61 11th June 2015 06:09 AM
naim cdi dodge Digital Source 5 16th July 2009 10:12 PM
philips cdm4?? fatchoy Digital Source 0 5th October 2007 04:10 PM
Philips CDI transport mechanism ash_dac Digital Source 1 13th May 2005 08:08 AM
