Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
The dynamic range of 16 bits
Old 21st June 2003, 08:03 PM   #231
Fred Dieckmann is offline Fred Dieckmann  United States
diyAudio Retiree
Default Maybe if we sing with Bing............
You've got to accentuate the positive
Eliminate the negative
Latch on to the affirmative
Don't mess with Mister In-Between
http://www.mathematik.uni-ulm.de/pau.../accent~1.html
Old 21st June 2003, 08:18 PM   #232
Christer is offline Christer  Sweden
Default Re: HAVING A FIELDDAY?
Originally posted by fdegrove
That the latest amp of yours, Frank? I can see valves on the
top.
Old 21st June 2003, 08:36 PM   #233
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
That the latest amp of yours, Frank? I can see valves on the top
Nope, a German "Kofferradio".
Let me assure you every bit is as important as the next in that one.
Frank
Old 21st June 2003, 08:40 PM   #234
I believe you and it seems to be four bits, counting the number
of valves. Maybe you can cascade four of them to 16 bits?
Old 21st June 2003, 08:45 PM   #235
fdegrove's Avatar
Only in theory....
Cheers.
Frank
Old 22nd June 2003, 08:23 PM   #236
jcx is offline jcx  United States
"Philosophers have argued for centuries about how many angels can dance on the head of a pin, but materialists have always known it depends on whether they are jitterbugging or dancing cheek to cheek"
"But 'glory' doesn't mean 'a nice knock-down argument,'" Alice objected.
"When I use a word," Humpty Dumpty said, in a rather scornful tone, "it means just what I choose it to mean – neither more nor less."
Today Humpty would write software; hardware engineers have always known the digital word zero doesn’t necessarily represent the analog voltage zero in any real ADC or DAC. But people do find it handy to use 2’s-complement and ignore the ½ lsb offset that comes along with dividing a symmetrical range into 2^^n-1 intervals. In fact “zero” in digital audio is often special cased in software and hardware allowing the distinction between a 0 level signal and “digital black” between valid data blocks.
If you choose to require that the digital code 0 to represent analog 0V and ask what is the smallest symmetric waveform amplitude then you get the 90 dB number that is causing so much consternation here
If you recognize that the most efficient use of your bits results in analog 0 volts being midway between 2 digital codes, the common 96 dB answer is about right for AC and consistent with the DC case where 96 dB is just right (for AC ½ lsb amplitude signal the amplitude of the fundamental of a square wave is ~ 2 dB higher than the square wave amplitude – this difference could be attributed to the correlation of the quantization noise which is causing further confusion and real distortion in the ½ lsb “sine” wave signal)
http://www.soundslogical.com/support...tml#P403_35603
Which is Right? – I vote neither
If you want to move beyond pinheaded angel counting and address practical audible resolution and 16 bit word length issues you quickly discover that digital domain manipulation must be done at high bit resolution and dithering used to create the final 16 bit representation. Using dither and noise shaping, audible resolution in 16/44 CD digital audio can easily exceed 96 dB – with the greater advantages of sub-lsb linearity and decorrelation of quantization noise – only people shipwrecked on desert islands, working with bamboo and coconuts have any excuse to be limited to undithered or 16 bit resolution editing for even 16/44 mastering
(see next page in first link)
http://www.digido.com/ditheressay.html
Old 23rd June 2003, 01:06 AM   #237
mbroker is offline mbroker  United States
mbroker's Avatar
Originally posted by Rob M
I also think everyone would agree that one could create a .wav file with only two sample values, giving an amplitude of -96dB with some DC offset. Yes? It's not especially easy to do that with cooledit, but all that tells us is that cooledit doesn't handle DC offsets very well.
Riiiiiight.....
Open Cool Edit. Create a new file, 44.1k, 16bit. Turn off dithering. Create a new wave with 50% DC offset, -6dBFS. Amplify it by -96dB. Zoom in, and you see a nice, but not perfectly symmetric, square wave with amplitude 1/2 LSB with a 1/2LSB DC offset.
I'd post the screengrabs, but it is really far too tedius.
Mark Broker
Old 23rd June 2003, 01:56 AM   #238
Pedja is offline Pedja  Serbia
Originally posted by mbroker
...square wave with amplitude 1/2 LSB with a 1/2LSB DC offset.
You will never, never get signal, offset or anything written as 1/2LSB. I have never tried CoolEdit, but from the screenshots already posted here it is obvious it oversamples – why and how, by default or not, I do not have a clue and it is not important for now, but screenshots showed bigger resolution than those original files had. It is not hard to understand this way it can easily and happily move something up or down for the level that matches to the 16bit’s 1/2LSB. The point is that you’ll never, never save anything of it into the 16 bit file.
I have some wav files considering this… if I do not post it in the next hour it means I went to sleep, but will post them tomorrow.
Pedja
Old 23rd June 2003, 02:05 AM   #239
Rob M is offline Rob M  United States
Riiiiiight.....
Okay, let me revise that.
It's not especially easy for me to do that with cooledit, but all that tells us is that I don't handle DC offsets very well.
Old 23rd June 2003, 03:08 AM   #240
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
JCX,
Well Said!
Who was that masked man?
There has been a lot of talk here about PCM coding but no specific reference to a standard (AES, ISO, EBU, SMPTE, Sony, Phillips…) that identifies that specific binary values against specific specific voltage levels.
Digression:
[Back in the steam driven days of Digital audio processing I became perhaps a little too familiar withy a DAW built by some bright guys up in Boston. It had a 16 bit I/O but all the mix, DSP and other editing was performed on a 56 bit buss. The DSP had no less than 16 Motorola DSP 5600 chips on two VME cards.]
The dynamic range of 16 bitsHide this!Advertise here!
Dynamic Range...? Lyra Digital Source 40 3rd October 2007 12:44 AM
Dynamic range vs Jitter ? ash_dac Digital Source 6 3rd March 2007 11:58 PM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 01:41 PM
