The dynamic range of 16 bits - Page 23 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 21st June 2003, 05:15 PM   #221
Now Fred almost agrees with me, that we get a squarewave.
However, if I get you right you are alternating between the
input values 0001 and FFFF so we have only two output values,
ie. a square wave, but the amplitude is "2 bits" pp (0001 - FFFF =
0002), ie. 1 bit peak, not 1/2 bit. To get the squarewave with
1/2 bit amplitude it seems we must add an offset to the signal
as SY suggested and as I used in my program that generated
such a squarewave. Well, now, what about larger amplitudes
than 1/2 bit? Do we still get a square wave? No, except for
signals of frequency 1/2 fs. Rather we do get at least three
distinct levels, as in the Stereophile diagram and in Steves
diagram. Well, I may be wrong, but this is my argument. It
is just a proof sketch, for the lack of time and a reasonable
way to write formulas (well, I could scan).
Mathematics ahead!!
"Theorem": With 16 bits, we can represent sine waves with
real-valued amplitude arbitrarily close to, but not including
the value 20log(2^-16) dB (which is approximately -96 dB).
Proof sketch:
One error that I, at least, have made is to not really bother
about the case where the source has a value not corresponding
to any of the quantization levels. It seemed not necessary,
but of course it is.
Let's suppose our input signal is a sine wave of amplitude A
and with angular frequency w, that is Asin(wt). We restrict
A to be a real number s.t. 0<= A <= 32767. For every sample,
the real-number value of the function must be converted to
an integer in the interval -32767..+32767, which I assume
is most appropriately done by rounding off to the nearest
integer. (Note that we cannot use the value -32768 when
representing symmetric signals with no offset).
Now, let's look at input signals at and just above the amplitude
0.5, and write the amplitude on the form 0.5+x, where x >= 0.
Define this signal as the function f(x), that is
f(x) = (0.5+x)sin(wt) , where x >= 0
and let r(x) be f(x) rounded off to the nearest integer.
Now, consider the case x = 0.5, that is f(x) = f(0.5) = sin(wt),
that is r(0.5) will have the values -1, 0 and +1. In each cycle we
get a sample sequence of the form
0,...,0,1,...,1,0,...,0,-1,...,-1,0,...,0
that is, a signal of the form shown in Stereophile, or in Steves
diagrams. We have one positive pulse of amplitde 1 and one
negative pulse of value one. This is a "two-bit" peak to peak
signal corresponding to a sine at level 20log(2^-15) which is
approximately -90 dB. (I will round off all dB figures, not the
formulas, to enhance readability).
Then consider the case x = 0, which means f(x) = f(0) =
0.5sin(wt). Since the max and min values are 0.5 and -0.5 and
these get rounded off to 0, we get r(0) = 0, that is no signal at
all!!! Since f(0.5) = 2f(0), f(0) must be a sine at level
20log(2^-16) which is approximately -96 dB. So, this proves
that we cannot record down to -96 dB then?? No, not at all.
We have forgotten that the input signal can take on any
real-valued amplitude between 0.5 and 1, i.e. we can have
x values between 0 and 0.5 (and, of course larger too).
Now consider an arbitrary value of x, s.t. 0 < x < 0.5. Obviusly
the function r(x) will be of the alternating-sequence form
shown for f(0.5), but the positive and negative peaks will
be narrower, just as Steve showed in his diagrams. i won't
go into trivial calculus details here, but we note that as the
value of x decreases, the width of the pulses decreases (the
width can be expressed in intervals of angular frequency, in
time intervals or number of samples, though the latter case,
gives us a further quantization in the time domain).
To sum up, for arbitrary x > 0, r(x) will be a signal with one
positive peak of value one and one negative peak of value
one, and the remaining intervals of the cycle have the value
zero. The width of the pulses decreases as x approaches 0,
and the pulses disappear at x = 0. What does this mean?
Well, it seems to me to mean that we can represent the
function f(x) for all real values of x down to but not including 0.
We get the smallest representable sine wave as the limes
of f(x) when x approaches 0, and this corresponds to the
amplitude 20log(2^-16), since it is the amplitude of this limes
sine wave, although a signal
of exactly amplitude 20log(2^-16) cannot be repsented. So
there is a difference between -96 dB and -96 dB The conclusion
would be that we can record sine waves with amplitude
down to, but not including -96dB (where 96 is a rounded off
value itself, to simplify).
Old 21st June 2003, 05:33 PM   #222
Pedja is offline Pedja  Serbia
Default Here we go again…
Originally posted by RobM
There are 65536 quantization steps, so LSB is 1/65536, or -96.33dB. Any other answer is wrong.
Give me that file which will show peak amplitude -96.3dB (or any below -90.3dB). In any analyzer.
Pedja
Old 21st June 2003, 05:50 PM   #223
SY's Avatar
Christer, "offset" is a term that offputs some people. You can equally well call it "asymmetry" (as I've said, people don't normally call a trumpet's waveform "offset"), or "scalar gauge," or a bunch of other things. The imposition of a symmetry requirement about an arbitrarily selected bit would trivially be seen to require three values, i.e., a two bit argument. But that imposition of symmetry was not a qualification of any of the original claims that are being discussed. The claims went to dynamic range (resolution) only.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 21st June 2003, 05:56 PM   #224
Default Addendum to previous "theorem"
I should, perhaps comment on one assumption I made in
the "theorem" above.
I assumed that the smallest signal we can represent is the
smallest signal that does not get represented as a sequence
of all zeroes. That is, it is the smallest signal that does not get
completely lost in quantization error. One might argue that
we should, perhaps, have some requirement for reconstruction
also, but I think this is the right way to define it. As I have
said previously, no sine wave can be represented in PCM
and fully reconstructed, no matter what level it has, no matter
what number of bits we use, and I am assuming a theoretical
DAC and a theoretical LP filter. I need hardly say how much
harder it would be in practice. So, if requiring reconstruction,
beyong not being reconstructed as a DC level, we cannot
really have any firm levels and say what the smallest signal
is. We can only do so under some extra condition for the
reconstructed signal (eg. less than a certain amoung of THD
relative to the original signal), a condition that is not, to my
knowledge, included in any PCM standard and thus would
be an added requirement, not present in the original problem
formulation. Adding for instance a THD limit as condition, would
give us not one value for the dynamics, but an infinite number
of values of the dynamics, one for each possible value of
the max THD allowed.
Old 21st June 2003, 06:02 PM   #225
Originally posted by SY
Christer, &quot;offset&quot; is a term that offputs some people. You can equally well call it &quot;asymmetry&quot; (as I've said, people don't normally call a trumpet's waveform &quot;offset&quot, or &quot;scalar gauge,&quot; or a bunch of other things. The imposition of a symmetry requirement about an arbitrarily selected bit would trivially be seen to require three values, i.e., a two bit argument. But that imposition of symmetry was not a qualification of any of the original claims that are being discussed. The claims went to dynamic range (resolution) only.
Yes, I agree. I didn't mean we should not allow "offsets", I
merely pointed out that it was not necessary to add a 1/2-bit
offset as I did in my program, after your suggestion. We can
get down to the -96dB limit even with signals symmetric
around zero, which my "theorem" says. Not sure what result
we get if taking away that constraint too, but I guess (time
for somebody else to the maths this time , that with offset
we can get down to the value 20log(2^-16) inclusive, while
with symmetry around zero we can only
come arbitrarily close to it. A distinction that is of no importance
whatsoever to others than us who are amused by theory. In
practice it becomes -96 dB in both cases.
Old 21st June 2003, 06:09 PM   #226
Default Re: Re: One, two, three... three or two, what do we need?
Pedja, assuming my maths is correct above, I would say it is
now clear that you will not get the correct answer from any
program. This would require the program to do the inverse
transformation from digital to analog domain (which is not
even possible for some data, the alternating unit sequence),
which would involve very heavy numerical computations
probably beyond what even a good PC today can do within
the time you are prepared to wait. I am sure the programs
just look at the actual digitalized samples and uses these
values as approximations.
Old 21st June 2003, 06:23 PM   #227
Steve Eddy's Avatar
You look rather lonely there, Rob. Care for some company?
As they say, two heads are better than one.
se
Old 21st June 2003, 06:45 PM   #228
diyAudio Retiree
Default two heads are better than one and two voltage levels are smaller than three
The the number of possible DAC output voltage levels for the smallest possible output signal.
Old 21st June 2003, 06:50 PM   #229
Default Re: two heads are better than one and two voltage levels are smaller than three
Hm, let's see, that's the "V sign", and V is roman 5, no that's too
many levels.
Old 21st June 2003, 07:02 PM   #230
diyAudio Senior Member
fdegrove's Avatar
Default HAVING A FIELDDAY?
Frank
Dynamic Range...? Lyra Digital Source 40 2nd October 2007 11:44 PM
Dynamic range vs Jitter ? ash_dac Digital Source 6 3rd March 2007 10:58 PM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 12:41 PM
Copyright ©1999-2017 diyAudio
