| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
I have an audio note kit dac board. A friend is going to get some I2S modules and send me one which I could put directly into my dac. It will convert the USB or coax (not sure which at the moment) directly to I2S. Could I then go right into the audio note DAC chip conceivably and bypass everything else? As I understand it the receiver chip is to convert from SPDIF to I2S, right? Or am I looking at a world of hurt?
#2 |
#4 |
Seems clear to me. He has a USB board which outputs I2S and hopes to snip the current inputs to the dac and hook the board. Question is whether the spdif receiver outputs I2S to the DAC and if not - how hard is to set the dac for I2S. A circuit will help. |
#5 |
Analog - exactly!
Here's what a digital friend said. Now I have to figure out where to put the wires from the M2Tech which will take USB to I2S. The AD1865 has 2 DACs with separate data paths. The good news is that the 74HC02 splits the data. You can remove U5(CS8414) and drive SDATA, SCK, and FSYNC from the I2S device. |
#6 |
And the bad news is that 1865 does not accept I2S directly.
| Please Explain direct to I2S USB DAC | JimOfOakCreek | Digital Source | 5 | 5th July 2008 07:57 AM |
| 2 PCM63 direct to I2S ? | Obelix | Digital Source | 17 | 24th August 2006 01:03 PM |
| Direct Wiring a DDDAC USB-->I2S to a P3A DAC I2S DIN input | dkj7a | Digital Source | 1 | 26th March 2006 05:46 PM |
| I2S direct on a Rotel 965BX | mevangel | Digital Source | 1 | 2nd February 2004 10:56 PM |
| I2S direct on a Rotel 965BX | mevangel | Multi-Way | 1 | 1st February 2004 06:47 PM |
| Page generated in 0.07623 seconds (74.73% PHP - 25.27% MySQL) with 11 queries |
