Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 16th June 2003, 06:17 PM   #1
Peter K is offline Peter K  Netherlands
Default Re-clocking the data with I2S
This might be a very stupid question, if so please forgive me!
I am using my CD-PRO2 drive with a 0-oversampling DAC based on 2 x TDA 1543. The DAC's input is I2S from the CD-PRO2.
I wonder if it makes sense to re-clock the I2S data at the input of the DAC. If so how do I do this?
Please your comments.
Thanks for reading.
Peter K.
Old 16th June 2003, 11:15 PM   #2
Here is an example. RECLK is 512 Fs
Old 17th June 2003, 08:02 AM   #3
Thanks for your reply. Can you please explain what you mean with 512 Fs in relation to the RCLK.
Best regards,
Peter K.
Old 17th June 2003, 05:49 PM   #4
512 Fs means the samplerate (Fs) multiplied by 512. In the case the 74HC74 flip-flops would have a 22.5792MHz clock with a CD source (512 x 44100Hz). It does not have to 512Fs. It could also be 256Fs but it must be synchronous with respect to the data lines being clocked i.e. the clock is an integer multiple of Fs otherwise one creeps into the world of samplerate conversion through the backdoor.
ray
Old 18th June 2003, 06:40 AM   #5
What are the requirements on the clock, must this be HQ? Do you have an idea where to find a complete diagram?
Thanks,
Peter K.
Old 19th June 2003, 12:25 AM   #6
Low noise and low jitter. Jocko Homo has posted a schematic for a clock on this forum and Elso Kwak has one he sends out on request. I have been content to use encapsulated oscillators that come in 8 and 14 pin dip sizes.
In the example I posted the clock came from a VCXO-based PLL locked to the FSYNC signal from the input receiver. For another example of a PLL based design see,
http://httpd.chello.nl/%7em.heijlige...tml/dactop.htm
There is an unconventional form of reclocking where the oscillator is freestanding and asynchronous with respect to the data and clock lines being reclocked. If this is what you are after then Elso Kwak is the man with the plan.
While it is useful to have a schematic there really isn't much more to reclocking that is applicable to a non o/s dac. All you have to do is decide on the nature of the clock you drive the flip-flops with.
Old 19th June 2003, 03:15 PM   #7
RFBRW,
Thanks for your information.
Best regards,
Peter K.
Old 28th June 2003, 07:40 PM   #8
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb Asynchronous Reclocking
Hi Peter,
If you are using Asynchronous Reclocking the clock frequency can be as high as 125 MHz. When using a asynchronous clock you need two filip-flops in series to avoid the metastabillity problem.. See Feddes site. For Asynchronous reclocking the frequency does not need to be a multiple of the CD-sampling frequency.
http://home.student.utwente.nl/f.s.b...dio/nonoz.html
Click on the schematic of the DAC.
The quality of the clock used is reflected in the sound quality of the result. Tones 80 MHz oscillator also works as well as Vite on Lines VCC1 125 MHz oscillator.
www.viteonline.com
Old 26th October 2003, 12:20 PM   #9
it is a very little trick that i have made with the elso kwak asynchronous relocker(ASR).
Old 2nd November 2003, 11:14 AM   #10
I'm sorry my first post was very short and I was on the moon.
The image post is not very good too.
Well,my trick seems strange and my explanation are far from perfect.
Let's go:
-when i lesson it,it's improve the sound.
-it cost nothing (2 resistors and a few coaxial wire).
-it's easy.
Well,why i have doing this:
-the three signals from the ASR are locked with the same very high frequency (100Mhz).
-a phase shift between this three signals can maybe (with bad luck) produce some audio noise into the tda1543.Why not,we use a phase shift(from the same signal) in radio to brodcast music(FM).
-if we can't suppress this phase shift we can increase it.
-bigger it is,higher is the frequency of the noise (whith luck over the audio frequency).
-the tda1543 tolerate some phase shift between the three signals.
How to do this:
-for increase the phase shift,we can use a Resistor Capacitor filter.
-100 ohm for the resistor.
-capacitor:capacitive effect of a coaxial wire.
-data signal is the reference:do nothing.
-word select signal:increase the phase shift between the word select signal and the data signal (use a 100 ohm resistor and 1cm of coaxial wire).
-bit clock signal:increase the phase shift between the bit clock signal,the word select signal and the data signal too (use a 100 ohm resistor and 2cm of coaxial wire).
Like this:the phase between the three signals are not equal or too close.
NOS re-clocking for cd player 1z2a3y Digital Source 2 28th June 2009 12:31 AM
Re-Clocking For Philips CD-950 terry2p Introductions 1 13th August 2005 06:50 PM
Re-clocking a must? Peter K Digital Source 41 23rd February 2005 02:56 PM
clocking the dac kozak Digital Source 0 25th May 2004 12:27 AM
Page generated in 0.12824 seconds (79.92% PHP - 20.08% MySQL) with 11 queries
