| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
#11 | |
![]() Working with SMD. How to do it without specialised tools.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#12 |
Thanks Mooly, I actually read that thread when it was new. In my case it will be even easier once I snip the legs off the old op amp. I'm mostly worried about lifting pads on these cheap pcbs.
When doing little mods, it would be nice to do one change at a time to be able to hear the effects of say, the diodes, then the caps, but then once you have it all apart and the pcb out you just want to get it all done and never go back inside. For sure, that OP249 was garbage, yet B&K had specially selected it for the AVP1000 preamp. |
#13 |
I am using the Chip Quick solder to remove the cips. It is working...
#14 | |||
![]() Quote:
Regading the dac chip, what would one change this 2 , what is a good ,better , best , DAC chip ? Quote:
Still looking for a service manual ..................... ! , |
#15 | |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Do those things really suck in a $2000 player though?
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#16 |
Go for it! Many separate supplies is something no player comes with as standard. Even the huge Naim ones with an external supply usually just tap off one tx winding and supply.
When you pay more you usually get better separation between power rails but it's typically just done using regulators, which is a great start (but can be improved upon significantly). This is the case up to at least £2000+ players. I've not seen inside many beyond that price point so I'm not sure if they go further with psu separation or not. Simon
Fave. threads: Marantz CD63 | Philips CD650 | my 3-way dipoles | T-bass for dipoles | EnABL treatment | Arcam Alpha (CD) |
#17 | ||
Power supplies, the importance of which is highlighted in the Jupiter. It has seven! Rega uses a high performance Sony CD mechanism, and to minimize the effect of footfalls, a case isolation system (they call it the Viscous Coupled Foot System, better known to us Regaphiles as 'squishy feet'). Along with the better power supply(s), the primary improvement is in the DACs. The dual differential 24 bit IC40 DAC chips are sourced from Edinburgh's Wolfson Microelectronics. Additionally, Rega has taken the greatest care with both data regeneration and clocking stages. |
| CD Player won't start | GringoAudio | Digital Source | 10 | 27th November 2007 04:12 AM |
| CD player mods - starting out. | RetroAudio | Digital Source | 0 | 20th February 2007 04:36 PM |
| Where to start on CD player mods and other Qs | Zero One | Digital Source | 5 | 18th September 2006 12:28 PM |
| Best cheap CD player to start modding...newbie, searched | ttrentt | Digital Source | 4 | 4th February 2006 10:17 AM |
| mods for old CD-player | static | Digital Source | 14 | 1st October 2003 05:27 AM |
