| Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc. |
Hello to All!
I wonder what would be the best option: I have 4x18[v] secondary transformer to power mentioned chips and small dilemma, should I share from one PSU -5V and -15V for TDA1541A and make separate PSUs for +5v, +5v for CS8412 and +5v for TDA1541A? One more question, as this going to be my first approach to DAC-built, where to place connection between chassis and ground, make star grounding from each PSU? Thanks in advance slav Last edited by slav; 7th April 2010 at 06:21 PM. |
#2 |
Any suggestions?
#3 |
Digital PSU can be common for CS and TDA. Analog power should be separate, and both grounds connected in a star - usually on the PCB, close to the DAC.
This is becuse the digital and analog GND are tied toghether inside the DAC anyway. |
#4 |
I'd say you'd be wanting lower voltage transformers for the +/-5v rails. I usually use 9v for these. Dropping from 18v (which will be 25vpost rectifier) will cause the regulators to get really hot. ALso, its worth considering that more seperation in rails is better. In my players I use sepreated regs for each device supplied and where possible seperate complete psu's including the transformer windings.
When Bitstream came out, I thought, “my God, what are we going to do...?” Ken Ishiwata http://www.hifisounds.co.uk Restek Fantasy, Audio Aero Capitole MKII, Focal and Kimber
#5 |
Following on from what UV101 has said using a lower voltage transformer also offers higher current capabilities over the higher voltage equivalent transformer. The more headroom you have on the current the better and lower noise the psu will become.
Brent |
| Tube-lover SE and Full Balance TDA1541a DAC | SamL | Digital Source | 155 | 23rd November 2009 12:18 AM |
| About a I/V tube ouput for a Nos TDA1541A dac | gaetan8888 | Digital Line Level | 1 | 10th July 2009 07:21 AM |
| Twin TDA1541A Tube DAC | DUC985 | Swap Meet | 3 | 13th March 2007 07:54 AM |
| Wanted: Dac pcb for tda1541a (non tube based) | ash_dac | Swap Meet | 6 | 7th January 2006 05:44 PM |
| Pics of my TDA1541A/CS8414 tube dac | HeadSh0T | Digital Source | 17 | 1st June 2003 10:31 PM |
| Page generated in 0.07341 seconds (74.45% PHP - 25.55% MySQL) with 10 queries |
