Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 2nd April 2010, 08:06 AM   #1
Ardee is offline Ardee  England
Default SPDIF Re-clocking
I am having trouble understanding how re-clocking data using a D type chip works.
The data is clocked to the rising edge of the master clock, which is fine if the data edge is always slightly behind the master clock edge. What happens though when a slightly jittery data edge corresponds with the clock edge? If the data edge is slightly behind the clock at one moment and slightly after it the next, will this not cause jitter of one clock period to be imposed on the data?
Old 2nd April 2010, 09:38 AM   #2
alexcp is offline alexcp  United States
alexcp's Avatar
That's possible, but unless the re-clocking clock frequency is an exact multiple of the datastream frequency, the probability of this happening should be low. You just get a slightly delayed but jitter-free copy of the original signal by resampling it with the (jitter-free) clock.
Old 2nd April 2010, 10:36 AM   #3
It is gonna happen eventually, no matter what. D type cannot eliminate the jitter by itself.
SPDIF it will "loose" samples with a separate clock if you don't use a buffer to compensate de differences in frequencies.
Anyway, can you post a schematics of what are you talking about so we are on the same page?
Old 2nd April 2010, 05:12 PM   #4
The kind of thing I am querying is here:
SPDIF Reclocking [English]
The only way I can see of doing this properly is to use a buffer and a synchronised source but no samples will be lost, as the master clock is running considerably faster than the incoming data rate.
Old 2nd April 2010, 06:49 PM   #5
Yep, that's not gonna work as described.
I would completelly recreate the CD-player (transport) clock signals from the external DAC clock.
SPDIF on cdrom to SPDIF on Digi Crossover davidallancole Digital Source 0 11th January 2007 03:26 AM
cdrom spdif quality / sound card spdif metebalci Digital Source 0 2nd September 2006 07:16 PM
Re-clocking a must? Peter K Digital Source 41 23rd February 2005 02:56 PM
clocking the dac kozak Digital Source 0 25th May 2004 12:27 AM
Asynchronous Clocking weinstro Digital Source 0 12th June 2003 05:31 PM
Page generated in 0.08308 seconds (73.32% PHP - 26.68% MySQL) with 10 queries
