Go Back   Home > Forums > Source & Line > Digital Source
Digital Source Digital Players and Recorders: CD , SACD , Tape, Memory Card, etc.
Old 1st April 2010, 06:52 PM   #1
danvee is offline danvee  United States
Default Service Manual/Schematic Philips CD680
I've just obtained a Philips CD680. It's in REALLY good shape, but it does need a little help sonically. I've modded many Magnavox models in the past, and the layout of this player is similar to the Maggie 471/2/3, but the mainboard is different, including a daughtercard for the analog outouts.
I've searched the 'net to the best of my ability and turned up nothing in the way of a service manual, or even much info at all on this player. It uses the venerable tda1541/saa7220 set.
If anyone here could help me, I'd very much appreciate it.
Thanks in advance,
Dan
Old 2nd April 2010, 12:34 PM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
I haven't seen the manual for this player around before, but most likely it's very similar to or the same as a few other Philips players. If you take a photo of the player's internals from above, I (or someone else here) should be able to find which manual will suit you best.
Old 2nd April 2010, 01:22 PM   #3
Default Great Idea!
I should have thought of that---Thanks!
Old 2nd April 2010, 04:59 PM   #4
Looks like my Sylvania CD1473 (that is actually a Philips CD473). TDA 1451, LM833... Yours has the headphone output on the right side, mine on the left (under the CD tray).
Old 2nd April 2010, 05:19 PM   #5
Thanks for the help!
Does your CD1473 have a remote volume control? The inverted board on this one has a pair of MC14051BCPs feeding an NE5532 to the L+R line level outputs. Looks like this would be part of a remote volume control setup.
Dan
Old 2nd April 2010, 06:18 PM   #6
Default Here's a shot of the daughterboard....
My guess would be that the red connector carries the R+ L+ and ground to the board. That's another reason for wanting the schematics.
The CD473 daughterboard appears to be different from this. I've posted the image from the CD473 Service Manual as well.
Old 2nd April 2010, 06:24 PM   #7
Yes, the board that is upside-down is the volume regulator with MC14051 and a NE5532 made by JRC (as a buffer). And yes, it has a remote that can control the output volume.
The one from the manual (that you posted) is the headphone regulator (has an separate buffer and an analog pot).
I have removed the LM833 from the main board and rolled some other OpAmps in that location. The best sound IMO was with LM4562.
Old 2nd April 2010, 07:16 PM   #8
Thanks!
I've had some pretty good luck with the 4562s as well, but they sound a bit "harsh" at times. I've been playing with the AD8620ARZs and those do well in my CDB650.
I'd really like to bypass all of that R/C volume circuitry and the extra op-amp, as I've no need for the R/C volume (and I don't have the remote, either).
I've also added an image of the "headphone board" from the CD473 S/M.
Maybe there are a few revisions not accounted for in the manual that I have.....
Dan
Old 2nd April 2010, 07:23 PM   #9
Don't worry about the headphones board, it is not in the way.
The gray connector brings the audio from the mainboard to the volume reg - you can bypass that. Just pull the big, green 100uF capacitors out and use a shielded conductor between the empty holes. Or you can leave only one capacitor in place to block the eventual DC offset component...
Or, if you look on the mainboard, there is a area with empty places where was supposed to be a fixed volume output. You can "build" that one.
PS; There where more that 5 "revisions" for the CD473, mine is similar with the ones labeled 01r, 05r, 07r
Old 2nd April 2010, 08:05 PM   #10
Something like this.
Looking for Philips CDD882 service manual eboy2003 Digital Source 0 9th January 2010 02:25 PM
Philips CD200 Service manual Scorpio(DDMF)! Digital Source 1 14th April 2009 09:34 PM
Philips CD624 service manual Stuey Digital Source 7 20th March 2009 07:49 PM
philips cd 880 philips cd880 service manual 0519 Digital Source 4 28th August 2008 11:43 AM
Philips CD880 Service Manual/Schematic? canuck Digital Source 5 22nd January 2004 03:27 PM
Page generated in 0.09474 seconds (85.70% PHP - 14.30% MySQL) with 11 queries
